Josh, I've been kneeboarding for several yeasrs now..i'm accually better at that than wakeboarding. I have just starting getting serious about wakeboarding this summer b/c its not as harsh on your knees and you can do more tricks. Any way on a kneeboard the best way to get big air is (my strong side is from right to left so i'll take ya through it like that)cut out hard to your right...pulling your hands in to your hip, then extend your arms through the transiting and pull your arms back inot your hip while making a hard cut towards the wake, cut through the wake and lean back just a litte bit so you will ride up the wake and not through it. Once you are in the air lean a little foward so you will land flat and not on the back of your board. Pulling the handle in to your hip will also give you a better landing. Hope this helps. If you want any more advice just ask..i can also do backrolls,180's and i'm working on a layout(basically a raley on a kneeboard) Brandon
