Old    deiselgrover            02-12-2004, 6:26 AM Reply
I am going to try wakeskatting for the first time this summer, and I was looking at buying a board that would be fairly cheap but would fit a novice. I am looking at a Double Up 2003 40. I am 5'11" and 175lbs. Would this be a good fit? Is this a "concave" board. I see it has a continuous rocker, does that mean it is concave? Also how much should I pay for it brand new?
Thanks for the help and sorry this is another what board should I buy thread. Did a search and couldn't find anything about it.
Also if this is not good you have any suggestions? I would like to spend around 70 or so. Also seems most people like the concave.
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       02-21-2004, 1:37 PM Reply
I have a flat, continious rocker available for $70 plus shipping. The DU stuff is great, just more expensive - about $120-130 depending upon retailer.
As for the debate between concave and flat. It is a matter of personal preferance. Slider riders like flats for predictability. Concaves cut better since the topography channels water and creates low-pressure areas. It is easier to cut without proper technique. I prefer to teach with flats so proper edging technique is learned and then put the more experienced rider on the concave.
Put out $70 now. Learn to ride and demo more boards over the next season or two. Then buy what your style needs - it is personal preference after all.
Old    deiselgrover            02-23-2004, 9:43 AM Reply
Thanks for the info Karl. What kind of board do you have available? Pics? Thanks again.
