Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 11, 2004
Old    Randy Murray (wakeripper)      Join Date: Oct 2002       01-30-2004, 9:58 AM Reply
I was just wondering if you fixed your trailer and if you eneded up doing a Tech article for it or not
Old    David Williams (wakeworld)      Join Date: Jan 1997       01-31-2004, 9:20 AM Reply
I did work on it. I used a wire wheel and some other rust-removing, sponge-looking device on my drill to get rid of most of the rust. I ran out of time, so I put some primer on it and it's been sitting ever since.
It's pitted pretty bad in spots, so I'm probably going to use some Bondo on it to smooth things out and then just paint it with a spray can. Most of it is under the diamond plate, which I intend to put back on with lots of caulking, so it shouldn't look too bad.
No article since I don't really know what I'm doing. There are probably better ways to take care of this, but I'm sort of an idiot! :-)
Old    English (kristian)      Join Date: Nov 2002       01-31-2004, 11:16 AM Reply
Simple solution, get your mooches to fix it, isn't that what they're there for anyways
