Old                01-28-2004, 1:42 PM Reply
What is the easiest way to learn a hoochie glid. i have head off the double up but not to sure any tips would be greatfuly apreciated
Old                02-02-2004, 4:05 PM Reply
rock into it. Like when you leave the wake get kinna rockin into it. And thenjust throw that hand back fast and grab it why its close..If you wait then it gets behind you and then you dont really have a chance.
Old    kyle (lfxstar)      Join Date: Jul 2001       02-10-2004, 8:16 PM Reply
okay POOLZY, there are two ways to learn a hoochie glide, off the wake, and the d-up, if you learn them off the d-up however you most likely wont be able to do them off the wake, so ill tell you how to do them off the wake. the key is not thinking of the trick as a raley, it is a COMPLETELY different approach. For a hoochie, you want to cut out about 5 feet less then you would for a raley and when you cut in, use a progressive edge with your knees bent. this is key. unlike a raley where you are just gonna charge, u need to come in with a crowched knee aproach. after you hit the wake, keep your knees bent and immediately reach back for the grab. the first few times i was learning this, i was throwing it like a raley and couldnt get the grab. by coming in with your knees bent, this will not be a problem. the first few times i did a hoochie glide and grabbed it, i had to look back for the grab, to ensure sticking it, this could end up in a bad fall, but hey, you are going to fall. the landing should be easy just like a raley and once you stick it, you will never want to do a raley again!!!!
Old                02-12-2004, 4:13 PM Reply
yeah 2ups helped me a lot.
Old                02-18-2004, 10:18 PM Reply
thanks heaps kyle
Old                02-20-2004, 8:24 PM Reply
wont your knees absorb the jump, and you'll get less air?
Old    Bennett (wakehype)      Join Date: Dec 2002       02-24-2004, 12:32 PM Reply
i think he was saying after you launch off the wake standing tall to focus on the tower and let your booard go behind you bending your kneews. a good example, take alook at aruns knees when he throws ahoochie
Old    Bennett (wakehype)      Join Date: Dec 2002       02-24-2004, 12:57 PM Reply
http://www.wakepics.com/view_single.php?medid=2206
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       02-24-2004, 1:54 PM Reply
actually that's an OHH, not a hoochie. :-)
Old    Bennett (wakehype)      Join Date: Dec 2002       02-25-2004, 4:45 PM Reply
yeah yeah, all i could find at the time ;)heh
