Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 11, 2004
Old    hyperliterider3            12-30-2003, 5:05 PM Reply
i am building a slider on a shallow part of my lake on some horse saws and ive made the horse saws and i dont know how to get the pvc to connect to the horse saws if u could drop a line to me that would be great
Old    mick139139            12-30-2003, 5:30 PM Reply
You might try one of these methods:
You can cut a hole in the side of the pipe and use a carriage bolt with a big washer .An other way would be, using a drywall fastener. You just need to drill a hole in the underside of the pipe. Just insert the screw from the underside,the drywall screw has some spring loaded brackets on the end, which will open up inside the pipe so you can tighten the screw in place.
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       12-30-2003, 5:32 PM Reply
attatch the saw horses with a wood beam( best bet would be a 2x6) and then screw the pvc to that. lay the pvc on it and drill holes on the top( the part that you would be sliding) so you can get a drill bit in to screw the pvc down. or you could try gettin pvc sheets and just make it flat instead of round like a pipe
Old    Mark (hiking42)      Join Date: Oct 2002       12-30-2003, 9:36 PM Reply
im thinking of making a slider while the water is down, can you get pvc sheeting at lowes or home depot?
Old    hyperliterider3            12-31-2003, 3:07 PM Reply
i have been to lowes and the home depot and i was looking for some of that and there was none here in B'ham
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       12-31-2003, 3:49 PM Reply
you can look for a product called trex, which is made for docks and decks. i have found it at home depot before. or you can go to a local docking supply company.
