Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through December 14, 2003
Old    sikboy            12-08-2003, 10:39 AM Reply
im a newbeee to wakeboarding "approx 10 times". ive just figured out how to jump from wake to wake sucessfully, now i want to learn how to do a 180.
i try but for some reason my back end just slides out and i end up falling backwards... kartweeling... you know the usual fun stuff.
can anyone tell me how they learnt to do this.
Old    English (kristian)      Join Date: Nov 2002       12-08-2003, 10:49 AM Reply
what your doing is spinning before you pop. Make sure you jump first, then rotate by bringing the handle in to your back hip.
Old    Skylar Dubrow (skydog96)      Join Date: Mar 2002       12-08-2003, 12:19 PM Reply
assuming you are regular, when pulling the handle to your right hip, rotate it so your thumb is pointing downward, this will put you over your board and help you not to slide out.
Old    Steven Hahn (solo)      Join Date: Oct 2001       12-08-2003, 12:29 PM Reply
Spot your landing then look for the shoreline.
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       12-08-2003, 12:43 PM Reply
can you do a 180 ollie in the flats? Learn this first.
Old    GD (greatdane)      Join Date: Feb 2001       12-08-2003, 12:57 PM Reply
Ride switch often.
Land on your toes and ride away on your toes.
Old    James B (jamesb)      Join Date: Sep 2001       12-08-2003, 2:50 PM Reply
Don't try to rush the 180 in the air, take it nice and slow. U should land with the board pointing as if you are going to cut out to the other side and make sure that you bend your knees alot when you land. Most people push out the tail of their board when first trying them because they are not taking it round far enough and landing on your TOESIDE edge.
Good luck, you will be stoked when you get it!
Old    sikboy            12-09-2003, 6:53 AM Reply
thanks fot the tips fellas..ill take your advice onboard and give it another shot next smash session!!!!!
