Mike Siepel's "Barefoot International" is a good beefy one. You would need to extend the cables that clip to the front eye at the bow of the boat, maybe with some climbing webbing and carbiners or an added section of cable. Of greater concern, I think the angle might be wrong. Normally on a direct drive, the boom bolts to the pylon pretty close to the floor, and that causes it to angle upward as it extends outward. If you try to clamp it on a V-drive pylon, the point of attachment will be pretty high up, which is likely to make the boom point down toward the water as it extends out. Not only will it be too low for a rider to hang onto, but much worse, it may dig in the water as you make a left turn and the boat leans to the port side. I promise, you do not want this to happen, it can trigger a very bad sequence of events. We were young and crazy back then and got off on crashing sh*t and tearing sh*t up, but digging the boom on a left hand turn at full speed was a mistake we only made once and were careful never to repeat. If you move forward with this idea, make sure you rig the boom somehow so it angles up toward the sky at least 20 degrees, preferably more, as it extends out from the side of the boat. If you can be clever and figure it out, it might be well worth it. Booms can be pretty fun and a great training tool, especially for kids, because you can cheer them on and talk to them face to face as you offer instruction and work on getting them into the proper body position. Good luck.
