Go Back   WakeWorld > Other Water Sports > Waterskiing
Old                08-28-2003, 6:54 AM Reply
I recently purchased a MB Sports BOSS 190 with GT-40 engine and perfect pass 5.0 digital pro.
2000 BOSS 190
I would like recommended maintenance info or any recommendations that people have experienced. So far the boat skis excellent with a very soft wake
Old     (bbeach)      Join Date: Jul 2002       08-28-2003, 10:06 AM Reply
Keep it clean! Wipe it down every single time you take it out of the water! Follow the scheduled maintainence to a T! Change the impeller every year no matter what. Don't put the boat away wet. Check oil often! Don't abuse the boat... Keep it off the docks and off the rocks and it will last forever! Wax alot too!
Old                08-28-2003, 3:57 PM Reply
First off, invest in a PP 6.4 chip and switch. Set you back $50 for the chip, and $200 for the switch assembly. If you already have a jump switch, you can cut the $200 down to about $50 I think. Between the speed changes and the software upgrades, its truly a necessary change.
Make sure you change your oil every 50 hours or so.
Make sure to check all the moving parts in your throttle and steering system every few months to make sure they're moving smoothly. Nothing worse than getting stuck in the middle of the lake because your steering cable or throttle cable snapped.
Be prepared to change you risers and manifolds every 500 hours or so.
Definitely follow KState's call on changing your impeller every year. Its amazing how easy those things go.
Finally, remember to check your water filter every time you go out. Only takes 30 secs to dump out any grass or debris sucked in there. Keeps the engine running nice and cold.
One last thing, don't forget to watch out for your trailer and keep up all the proper maintenance (tire pressure, hubs, bearings, lights, etc.).
Enjoy the boat. It looks beautiful.
