Old                08-03-2001, 4:03 AM Reply
Any tips on doing a raley on a cable tow ??
Old    hard 2 explain            08-03-2001, 3:05 PM Reply
well first you need 2 get a decent cut so you should practise 4 a while cutting as hard as you can heelside! so u are virtually @ 90degrees 2 the cable this will load up the line! so u can get so good air! once u feel u have loaded up the line enough let it go but do it while u r still putting alot of tension on the line!!! you then need 2 let the board go up how ever u feel comfortable!!! i do it by pushing my feet up and by in a kind of twisting motion (hard 2 explain)! at this point u need 2 keep your head up & shoulders back or it becomes a face plant!!! and as the handle starts 2 move up 2 about level with your eyes u want 2 start bringing it back down!! pulling it down 2wards your knees helps bring the board back under u!!! it will take a while 2 get right!!! u should also talk 2 the guys down @ the cable that pull raleys and talk 2 the cable operator!! they will b able 2 give u usefull hints!!
Old                08-06-2001, 2:56 AM Reply
cheers tom.
