Old     (ragboy)      Join Date: Aug 2007       12-19-2019, 2:58 AM Reply
So I did a review on the 550 and went deeper than I normally do. I couldn't help but think about wakeworld. In the video I discuss 5 years of history and go back to the beginning of surf systems and talk about some of opinions of myself and those in the "hard core wakesurf community". Which for the most part, I meant conversations and arguments had on here. Back in the day when wakesurf engineering was done by all of us that loved the sport. So I guess the video for me is about me feeling like I can give up on that, since manufacturers are doing such a great job, well, many of them.
Let me know what you think. ;-)
Old     (Entersandman)      Join Date: Jun 2015       12-23-2019, 11:44 AM Reply
Thanks for the review and history lesson Ragboy. Your videos have been helpful in my family choosing our next boat a leftover 2019 SL 400. Its been cool to watch the Supra line grow and change over the last few years.
Old     (Fixable)      Join Date: Oct 2012       12-31-2019, 2:00 AM Reply
Ragboy- So, me and my buddy have the boats in the pictures below. A 2020 SE550, and a 2020 XStar. Both are stock with the exception of 250lbs of lead under port coffin seat to offset prop rotation. Both boats running stock settings for the steeper type wave.
As you can see, one is in a whole different league than the other. I was thinking you had one of the new SE's at one point? Any suggestions you could offer? We have tried it with Autowake, and without. It has also gone to the dealer a couple times to verify everything is operating perfect.
pics are of same rider, same lake, same day. I have more, but figured this was the best reference. IIRC, there was only 4 of us playing that day. Wave is much smaller, much shorter, and a lot less firm. I'm thinking there must be some little things we can do to get the wave up to the level of the Star?
Old     (Entersandman)      Join Date: Jun 2015       12-31-2019, 3:28 PM Reply
Ragboy (aka Wake9) has a few videos on setting up the SE 550. Here is one where he explains an adjustment to better setting it up. Go through his vids and you should see how he has his SE 550 setup.
https://www.youtube.com/watch?v=OrfX6e_lxpk
Old     (wombat2wombat)      Join Date: Sep 2018       01-02-2020, 2:53 AM Reply
Hows the wave on the SA 400? Have my eye on one. Have my eye on a nice 550 but it's too dang far away
Old     (83Starsnstripes)      Join Date: Jul 2013       01-03-2020, 6:48 AM Reply
New 2020 SA is really nice. Basically a smaller version of the SE.
Judging by that SE wave pic looks like you don't have it set up correctly. If you didn't calibrate the Autowake it can definitely make the wave not so great. Also, we've noticed less Surf Swell Plate the better and more rear weight or more "pitch" the better, especially if you are looking for a steep wave. I'm guessing that picture was just in a turn randomly but turning while surfing will also ruin your wave on these new boats.
That SE wave is amazing.
Old     (downfortheride)      Join Date: Jun 2005 Location: SLC, UT 5600'       01-05-2020, 6:29 PM Reply
Drive that SE straight
Old     (Fixable)      Join Date: Oct 2012       01-06-2020, 4:51 AM Reply
Apologies, that was shortly after the pull up. We were going straight at that moment, but had only straightened up a few moments before.
I mean, its not like we don't know that we have to be going straight.....
But here is a pic after a long period of time going perfectly straight. As you can see, it is the same result.
Thank you for the other input. We have tried some of the things mentioned, but there were some other things in the vids that we can try. The wave definitely gets bigger/better with a large crew, but that is not a common occurrence for weeknight surfs.
Old     (83Starsnstripes)      Join Date: Jul 2013       01-06-2020, 7:20 AM Reply
Do you know what the plate settings are? Did you calibrate your Autowake before starting out?
Old     (Fixable)      Join Date: Oct 2012       01-06-2020, 8:30 AM Reply
Autowake calibration was done a couple times by the owner, with the dealer, because he wanted to make sure it was done right. Does he need to recalibrate every time he uses it? I donít think a calibration was done that day.
Plate settings were the stock settings. We tried it with the center plate all the way up, which helps a bit with the push/feel of the wave, but makes it dirtier. We didnít mess with the surf tab settings except to switch between the factory wave types. I donít remember what the stock deployment values were for the surf tabs.
Also of note- the goofy wave is much better. Maybe not setting the world on fire, but itís at least 50% better than the port wave.
Old     (83Starsnstripes)      Join Date: Jul 2013       01-06-2020, 9:21 AM Reply
You might want to calibrate the Autowake or at least make sure all the ballast is 100% full.
The center plate should be around 25% or less. And the opposite plate will vary depending on what you want but typically 45% for a port side wave and 65% for a starboard side wave. Hope that helps!
Old     (Fixable)      Join Date: Oct 2012       01-06-2020, 10:08 AM Reply
Thanks, 83sns. We will give that a shot this spring.
