Old     (davesetter)      Join Date: Jan 2014       11-16-2018, 5:45 AM Reply
Just bout a Promariner 8 onboard charger to install in my 2017 22 MXZ. Installing looks simple. It comes with 60Ē cables but you can purchase extensions. The install instructions say to mount it as far away from the batteries as possible and to not mount over carpet. Suggestions on mounting locations and any other thoughts would be appreciated.
Old     (spencerwm)      Join Date: Feb 2009       11-16-2018, 9:15 AM Reply
I would suggest placing it under one of the side seats and mounting to a seat base wall. I have seen them mounted under the rear port side seat cushion.
Old     (grant_west)      Join Date: Jun 2005       11-16-2018, 2:25 PM Reply
You can do this. Find a dry location that has lots of air flow. Donít mount it where you keep wet jackets or towels or where it gets wet. Becasue when you turn it on it creates heat and can draw in moisture. Also you donít wanna have items rested up against it. The charger when itís going needs or should have air flow around it.
I would make a mount plate for it. Get a 1/2 thick piece of ABS and cut out the carpet and glue the ABS to your Hull. This will be the mount for where the charger mounts. Then you can screw the charger into the ABS.
Sorry I donít have a better pic of my charger and how itís mounted.
Old     (h20king)      Join Date: Dec 2009       11-17-2018, 5:50 AM Reply
Here is a couple pics of the one we installed in our last boat. It's in a centurion fi23 but should still give you the idea.
Old     (davesetter)      Join Date: Jan 2014       11-29-2018, 9:41 AM Reply
Awesome. Thanks for the input!
