Old     (Bengarrison208)      Join Date: Aug 2017       09-07-2017, 1:36 PM Reply
So I need to relocate the battery to make room for bigger ballast bags in my rear locker.
I need to move the battery approx. 10-12 feet and was wondering what gauge wire I should go with?
I believe it's currently 8 ga. for both the power and ground.
I don't plan on adding another battery.
Thanks!
Old     (Stokes760)      Join Date: May 2017       09-07-2017, 1:38 PM Reply
Figure out amp out put of alt. measure the aprox length of wire and look up a 12volt wireing guide chart
Old     (Bengarrison208)      Join Date: Aug 2017       09-07-2017, 1:50 PM Reply
Got it. Thanks
Old     (chpthril)      Join Date: Oct 2007       09-07-2017, 2:13 PM Reply
You need to go by starter draw, not alternator supply. A typically alternator might be a 90A or less. Starter current draw in amps, is 200-300 amps.I think you are looking at 2ga at least, maybe 1/0ga.
Old     (Bengarrison208)      Join Date: Aug 2017       09-07-2017, 2:25 PM Reply
Ha! I found the battery cable recommendation part of the Merc Service Manual.
It states 9.5 to 12 ft. use 0/00 gauge wire. Maybe I'll try to find a closer place to relocate the battery to keep the gauge smaller.
Old     (denverd1)      Join Date: May 2004       09-07-2017, 2:54 PM Reply
under rear seats is a good option. don't be afraid to cut out some glass (non structural of course) and build a spot for it.
Old     (Bengarrison208)      Join Date: Aug 2017       09-07-2017, 5:21 PM Reply
I hadn't though about cutting a spot... Thanks!
Old     (denverd1)      Join Date: May 2004       09-08-2017, 7:05 AM Reply
I'd drill the corners and jigsaw the rest. use painters tape to the glass from splintering
Old     (soonerbilly)      Join Date: Jul 2013       09-08-2017, 7:37 AM Reply
I moved mine a few years ago....that wire aint cheap.....move them as little as you can get away with.
Old     (denverd1)      Join Date: May 2004       09-08-2017, 7:57 AM Reply
not familiar with your boat, but there should be a few places to access trans and vdrive. remove the covers and look around in there. might help you find a good spot for it. just make sure you know what's behind the area your cutting out.
Old     (denverd1)      Join Date: May 2004       09-08-2017, 8:16 AM Reply
more ideas... if you have AGM batts you can mount them on their sides. might open up a few options
Old     (WheelerWake)      Join Date: Mar 2013       09-08-2017, 4:11 PM Reply
Keep in mind, your battery weighs more per volume than the water that's going to replace it.
Old     (Bengarrison208)      Join Date: Aug 2017       09-09-2017, 8:51 PM Reply
Been looking for a spot to place the battery without having to move it to far. There are a few spots, but nothing deep enough for the current battery.
I might just move it to the front of the locker. Would allow the my bags to fill more completely and be more to the rear of the boat then they currently are. And I could use the current wiring. Otherwise I'd probably need to run a 0 gauge wire to under the observer seat area.
Thanks for the advice.
Old     (GSXRcrasher)      Join Date: Jul 2013       09-10-2017, 10:38 PM Reply
I relocated both of mine underneath the little cubby hole with the two cup holders on the starboard side. I had to cut an access hole in the front of the starboard rear storage area. I was able to just pull the carpet up out of the way to cut the hole then lay the carpet back over the hole once I screwed the cut out piece back in. I'll shoot some pictures tomorrow and email them to you.
Old     (denverd1)      Join Date: May 2004       09-11-2017, 7:57 AM Reply
battery + water is you're shooting for
Old     (Bengarrison208)      Join Date: Aug 2017       09-11-2017, 9:20 AM Reply
I did some more measuring if I order custom ballast bags from Wakemakers, I should be able to up my ballast weight to approx. 1200-1400 lbs. in the rear lockers and just move my battery to the front of the locker and maintain the factory wiring. I think that's what I'll do.
Trevor - I am interested to see how you got those under the cubby, sounds tricky.
