Old     (IanDB)      Join Date: Mar 2017       06-01-2017, 4:19 AM Reply
Hi. I chipped a ding on the rail of my new Haze Wakesurfer at the weekend.
Anyone done this and repaired it?
Any suggestions on what I should use please?
Old    Anastazi Sarigiannis (Stazi)      Join Date: Sep 2011       06-01-2017, 5:54 AM Reply
This stuff is the best! Cures in the sun super fast.
Phixdoctor FTMFW!
https://smile.amazon.com/gp/aw/d/B00...s-L&ref=plSrch
Old     (IanDB)      Join Date: Mar 2017       06-01-2017, 7:18 AM Reply
Thanks.
Is it easy to sand down?
Any other suggestions anyone has used?
Old    Jack Henry (racer808)      Join Date: Jan 2013       06-01-2017, 7:37 AM Reply
Loc tite two party epoxy from Home Depot works great & it sands down easy after dry, dry clears as well. I mixed in some black paint from a vinyl repair kit I had to fix a blemish on a black board & you couldn't tell it was there unless you knew or stared at it long enough.
Old    Anastazi Sarigiannis (Stazi)      Join Date: Sep 2011       06-01-2017, 7:44 AM Reply
The Phixdoctor uses a clear plastic overlay while it cures, so it cures dead smooth. You can sand later if you like. Haven't found anything as easy and as fast to fix surfboard dings.
Old    Nick Wiersema (Chaos)      Join Date: Apr 2010       06-01-2017, 10:15 AM Reply
You can use the sun cured epoxy, but it is better to use a two part. UV cure 'epoxies' don't really work. It is only a temporary seal and will likely continue to leak.
http://chaossurfco.com/ding-repair/p...ing-repair-kit
http://chaossurfco.com/ding-repair/c...ing-repair-kit
http://chaossurfco.com/ding-repair/1...-fiberfill-kit
Old     (IanDB)      Join Date: Mar 2017       06-01-2017, 10:41 AM Reply
Great. Thanks all for your help.
