Old    Shane (srich5)      Join Date: Apr 2016       02-23-2017, 11:38 AM Reply
How fast does everyone normally tow their boat? I usually stick to about 70 on the interstate. I am always having problems with tires and I am trying to solve the problem. I typically inflate them all to 50psi before taking off on a trip.
Can you pull them faster with 18" rims?
Old    Anastazi Sarigiannis (Stazi)      Join Date: Sep 2011       02-23-2017, 11:55 AM Reply
All depends on the speed rating of the tire. Check your sidewall for information about max speed. If it doesn't say specifically, it with have an alphanumeric load rating which also corresponds to a maximum speed
Old    Paul (psudy)      Join Date: Dec 2003       02-23-2017, 12:32 PM Reply
75-80.
Old    Brian (Ewok01)      Join Date: Apr 2013       02-23-2017, 4:40 PM Reply
Here are two links, the first is from the Goodyear Marathon RV/Trailer website, the second is from Kuhmo Radial 857 website. They both have a guide for tire inflation and if you inflate to 50 psi, you're only good up to 65 mph.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
http://www.kumhousa.com/tire/categor...E-E59335DE416C
Old     (WheelerWake)      Join Date: Mar 2013       02-23-2017, 8:31 PM Reply
Goodyear's info on trailer tires and speed:
https://www.tirerack.com/images/tire...plications.pdf
Old    Matt (That_Guy)      Join Date: Aug 2015       02-23-2017, 9:00 PM Reply
I run close to 75 on my 5-6 hour haul to the lake every few weeks in the summer.
Old    Jason W (Medium)      Join Date: Aug 2011       02-23-2017, 9:08 PM Reply
What does everyone inflate their trailer tires to?
Old    Art (rallyart)      Join Date: Nov 2006       02-23-2017, 11:53 PM Reply
18" rims make no difference in a functional tow speed. If you run speed rated auto or LT tires they will handle the speed better than a trailer tire, if they have the load capacity. There are many factors that can make trailer tires wear or blow out. Load and inflation pressure are key but if you are on a dual axle trailer it is the load on each of the axles that you need to check, and that's hard without individual scales. It can also be due to alignment problems with the trailer tires.
Old     (WheelerWake)      Join Date: Mar 2013       02-24-2017, 4:36 AM Reply
Many people just inflate them to them max pressure listed on the sidewall, regardless of the load. I've always inflated mine based on the Goodyear chart referenced below. They are currently at 40psi.
Old    Shane (srich5)      Join Date: Apr 2016       02-24-2017, 8:51 AM Reply
It looks like almost all trailer tires have a speed rating of 65. I wonder if passenger car tires are better? I have had great luck with horse trailer tires and they carry way more weight but I have had poor luck with boat tires. I think overall, they are a very cheaply made tire compared to car or truck tires. Most of them are only rated for 5-12k miles.
Old    Todd (antoddio)      Join Date: Dec 2006       02-24-2017, 12:33 PM Reply
Yea, 65 will be the highest you can get, but it's more a factor of weight and speed. Run them faster and they build up for heat for a given load.
I've had no issues with trailer tires...run them overloaded, underloaded, low pressure, over curbs, scrape the sidewall, pushing the sideways over asphalt, inflated and deflated dozens of times, etc. They seem indestructible to me. Just my experience.
Old    Nailem (nailem)      Join Date: Apr 2011       02-24-2017, 12:57 PM Reply
I have had bad luck in the past with blown trailer tires that look to be in great shape. I was told the last time to make sure the tire PSI is up near the max rating for the tire. One of the worst things for a tire is heat, heat will generate faster if the tire is under inflated. He also said there is a date code on the side of each tire and trailer tires are only good for 5-6 years. I thought this was just bs from a guy trying to sell tires but all the tires that I had problems with that looked good were 7-9 years old. My brother-in-law blew a tire that was 8 years old and looked good.
I will replace mine every 6 years just to make sure.
Old     (WheelerWake)      Join Date: Mar 2013       02-24-2017, 2:48 PM Reply
This is good advice, I had an 8 year old tire on a car, that looked perfect, yet came unglued driving ~ 75mph.
Old    Hey, You scratched my anchor! (bftskir)      Join Date: Jan 2004       02-24-2017, 3:46 PM Reply
Any vehicle towing anything is limited to 55 mph in California. Running faster than 65 is begging for a ticket.
Old    Jack Henry (racer808)      Join Date: Jan 2013       02-25-2017, 3:42 AM Reply
I prefer light truck tires rated for the load. On my current trailer though my rims are too small so I'm stuck using carlons.
Old     (WheelerWake)      Join Date: Mar 2013       02-25-2017, 6:00 AM Reply
That's got to be pretty annoying.
Old    Hey, You scratched my anchor! (bftskir)      Join Date: Jan 2004       02-25-2017, 9:00 PM Reply
I may tow as fast as 70 but not in the vicinity of a Highway patrolman
Old    Nacho (denverd1)      Join Date: May 2004       02-27-2017, 9:11 AM Reply
got car tires on mine. better load and speed rating
Old    John (MBBoss210)      Join Date: Jan 2014       02-27-2017, 1:56 PM Reply
Yeah, here is California any vehicle towing a trailer is limited to 55MPH. I usually set it on CC for 60MPH and enjoy the drive. Never had any issues with my tires, which is also helped by the slower towing speed I'm sure.
Old    Joe Brown (Darkside)      Join Date: Apr 2015       03-09-2017, 10:42 AM Reply
I tow at the speed limit up to 75. The caveat the boat is on a triple axle and I tow with a diesel 1 ton dually. So even at that speed it's very stable, I used to order tandem axle but they felt a little loose at higher speeds. So with tandem I rarely towed over 65.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       03-09-2017, 3:13 PM Reply
I run about ~75.. I stop after 10 miles and check tires and hubs with the IR gun. If all is good Ill check again after about another 50. If all is still good I just keep going. I run 4 hours to the Keys every other weekend all summer and one big 13 hour haul to a TN lake end of summer. Big tandem trailer running 15" wheels and trailer radials.
Old    Cory D (cadunkle)      Join Date: Jul 2009       03-16-2017, 6:29 PM Reply
I run 65-70. Never had a trailer tire failure. I forget what brand but I got them at the local trailer place already mounted on 15" steelies. I forget psi, but I run them near max, maybe 2psi under.
Old    Rick (CALIV210)      Join Date: Jun 2015       03-17-2017, 8:39 AM Reply
I run up to 70..... you know on private highways lol (California) .
I think trailer tires are just cheap a$$ tires I take good care of my tires, brakes,and bearings and have still had failures . Heat is a big factor and anytime a tire has failed on me has always been a super hot day. I'm going to switch to car tires soon as have a set of 15 inch Chevy Rally wheels Painted white with chrome center caps and rings to match the boat and trailer I'm going to mount up . I'll be sure to keep everyone posted on how well the car tires do .
Old    Bob Clark (Bob232)      Join Date: Mar 2017       03-20-2017, 10:16 PM Reply
I am excited to see the end result. Please keep us updated.
Bob Clark
www.alexandriavatowing.com
Old     (WheelerWake)      Join Date: Mar 2013       03-21-2017, 4:50 AM Reply
When putting new rims on a trailer, keep in mind trailer rims usually have a higher capacity that auto rims, both load and psi. Truck rims are usually similar to trailer rims.
Old    Rick (CALIV210)      Join Date: Jun 2015       03-21-2017, 6:31 AM Reply
Bob Clark
I will !!! i'm pretty excited my self . I hope it looks as clean as I think its going to .
Old    Rick (CALIV210)      Join Date: Jun 2015       03-21-2017, 6:33 AM Reply
I knew that but I figured if they can take the weight and abuse of a big block powered Chevelle or Impala they better be strong enough for my little Sanger . lol
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       03-21-2017, 9:08 AM Reply
Next time I need to replace a trailer tire I'm just going to find some good used 17" mustang rims with good tires and run them. I haven't heard of many people that have car tires on a tandem axle trailer, pulling a wakeboard having any problems.
Old    Bob Clark (BobClark123)      Join Date: Mar 2017       04-17-2017, 9:00 AM Reply
They say speed is dependent on the weight of the boat and the ability of the tower.
Jeff Farmer
Old    Tim (srock)      Join Date: Mar 2002       06-12-2017, 12:39 PM Reply
Throw them out after 6 years and "exercise" and heat them up if they are just sitting.
