Old    L.D. (ldeisel42)      Join Date: Nov 2009       08-26-2014, 9:39 AM Reply
A debate with a friend got me curious... What would it cost to replace motor such as monsoon 330 or something similar? Anyone had to replace one? If so what it cost ya?
Old    Bryce (brycejb328)      Join Date: Aug 2009       08-26-2014, 10:11 AM Reply
About 5 years ago I did a 350 ci longblock, I was right at 2k for the whole job. Including replacing some miscellaneous stuff while I had it all apart. This was from a local engine company.
Old    Jeff D (Jeff)      Join Date: May 2010       08-26-2014, 10:21 AM Reply
I haven't had to do one yet but it's reportedly pretty painless. You can get a rebuilt Vortec 5.7L which would be suitable for most Indmar or PCM boats for $2,300+shipping here:
http://www.michiganmotorz.com/vortec...rent-p-68.html
I'd be willing to bet you could have the engine rebuilt locally for less if you removed/re-installed it yourself if you could find a reputable shop to do the work.
Or a new engine for $2,749 + shipping:
http://www.michiganmotorz.com/350ci-...ent-p-109.html
In either case you'd have to transfer all the accessories, intake manifold, water pump etc. over to the new block.
Old    L.D. (ldeisel42)      Join Date: Nov 2009       08-26-2014, 9:12 PM Reply
Thanks. I figured a motor could be replaced for 5k or so. I was just curious what ppl experiences were.
Old    David (99Bison)      Join Date: Sep 2012       08-26-2014, 10:54 PM Reply
Depends on what all you are replacing... If it's a total drop in performed through a dealer it's roughly likely around 8k. At the other end, new long block or local rebuild with new internals that you reinstall could be had in 3k range. Or if you piece meal it together could spend 10k on internal and external parts and machine shop work alone.
Old    Cory D (cadunkle)      Join Date: Jul 2009       08-27-2014, 7:43 AM Reply
SBC will cost anywhere from $500-$2500 depending on what it needs and what your goals are. If yours is cracked then you're gonna be towards the top of that as a core to build can be $100 to a few hundred, or towards the top of that for a nicely built lower miles/hours that you can just drop right in. Create motor? I'd say $2500 would get you a nice stock HP level engine ready to bolt your marine stuff onto, but I don't trust big rebuild shops as I've seen a lot of mishmash mixed parts and corners cut that I would never do.
Old    Jman (jmanolinsky)      Join Date: Dec 2005       08-27-2014, 10:02 AM Reply
Here is a sale on a 350 from JEGS for $1260 with free shipping!
http://www.ebay.com/itm/Chevrolet-Pe...-/400444180233
Old    Jman (jmanolinsky)      Join Date: Dec 2005       08-27-2014, 10:21 AM Reply
BTW: The above engine is a GM Goodwrench 350ci Engine with 4 bolt mains.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       08-27-2014, 10:51 AM Reply
pretty sure that jegs motor is the "old" 350 without vortec heads.
Old    L.D. (ldeisel42)      Join Date: Nov 2009       08-27-2014, 11:37 AM Reply
My boat is fine. My friend saw a boat on Craigslist at a great price and I said "at that price you could put a motor in it and be fine ". Then the debate insued ha.
Old    Hey, You scratched my anchor! (bftskir)      Join Date: Jan 2004       08-29-2014, 8:43 PM Reply
I had a 1990 350 with 260 hp that leaked water at the intake gasket/head gasket so I upgraded to a 2011 Mercruiser 383 mag mpi stroker with 350 hp drop in plug and play 8500 and i sold off my old engine and components for 1500.
Old    Marty Crawley (GoneBoatN)      Join Date: Jun 2014       09-02-2014, 9:29 PM Reply
I think a lot depends on the age of the boat. Older boats with little to no electronics but otherwise a good hull, that might be a solid plan for a low budget but solid boat. Don`t forget about the tranny too.
On newer boats which have much more electronics, I'd be concern about those components as well.
I ponder this question because when time comes and I have gobs of hours on the engine I wonder what I'll be doing.
Old    Bryce (brycejb328)      Join Date: Aug 2009       09-03-2014, 8:30 AM Reply
a long block is a long block... unless I am completely missing something... I don't believe the technology surrounding the long block would increase the cost of replacing it. Maybe in the way of labor, but product cost shouldn't vary all that much...
The recent inception of "weird" displacement engines that are being marinized may be a different topic to debate as the inventory isn't quite as plentiful as your basic 350 c.i. long block that has been used for ages.
Old    Marty Crawley (GoneBoatN)      Join Date: Jun 2014       09-03-2014, 9:25 AM Reply
The point being that the idea of refurbishing an old boat, going forward with the newer electronics, the engine may be the least of your worries. Where you have a boat that is pre-all-so-much -electronics I think an engine replacement is a reasonable consideration.
With the newer boats that have almost all the functions controlled through a touchscreen, all that has to happen is for the OEM of those electronics to decide to no longer manufacture a part. So what I'm saying it is going to get interesting in the future on keeping such a boat running for a long life time. Consider that features such as cruise control (generic name), gauges (speed, temp, rpm), ballast systems, etc are being controlled through a central module now days.
