Old    Mike Webb (Thedudeparty8080)      Join Date: Aug 2013       08-07-2014, 6:46 PM Reply
Surf gate fault. Max current draw retracting right. What does it mean..
Old    Tim (dezul)      Join Date: Jul 2012       08-07-2014, 7:01 PM Reply
Give a better explanation. Your lack of detail does not explain your issue.
Old    Tim (dezul)      Join Date: Jul 2012       08-07-2014, 7:02 PM Reply
I am guessing you have a warranty issue. Take it to your dealer.
Old    Mike Webb (Thedudeparty8080)      Join Date: Aug 2013       08-07-2014, 7:06 PM Reply
Thats the explanation. You must not know than.
Old     (WakeDirt)      Join Date: Jun 2011       08-07-2014, 7:34 PM Reply
I think a 7 year old has gotten a hold of your computer.
Old    Aric Brabec (aricsx15)      Join Date: Jan 2014       08-07-2014, 9:43 PM Reply
Dealer will probably have to replace the rams on the surf gates. happened to my buddies 14 lev
Old    Mike Webb (Thedudeparty8080)      Join Date: Aug 2013       08-08-2014, 3:42 AM Reply
Aric Brabec thanks man.
Old    Dave (wakebrdr94)      Join Date: Jul 2010       08-08-2014, 9:18 PM Reply
It means you have gone faster than surfgate is designed for and is bringing the gate back to stowed position. Usually happens when people forget to turn surfgate off when done surfing, then throttle to normal speeds
Old    Arrowhead Boat Sales Beaver Lake (ArrowheadBoatSales)      Join Date: Oct 2013       08-09-2014, 6:27 AM Reply
or, there is an obstruction not allowing the gate to retract back towards the swim platform.
Old    Frank Berg (Iceberg)      Join Date: Dec 2011       08-09-2014, 7:16 AM Reply
Or the screw is jacked!
Old    Rob Pitchford (rob_pitchford)      Join Date: Nov 2004       08-12-2014, 11:49 AM Reply
Incorrect Dave Diaz. This is not the error you get when exceeding the max speed. Max current draw error is likely caused as Aric suggested by a Ram that will need to be replaced. The Lenco worm drive rams do occasionally leak and once water is in the ram its only a matter of time till it fails.
Old    Dave (wakebrdr94)      Join Date: Jul 2010       08-12-2014, 11:06 PM Reply
test it. Leave surfgate activated and exceed the 13-14 mph. You will get the max current draw, retracting.
Old    Mike Webb (Thedudeparty8080)      Join Date: Aug 2013       09-02-2014, 6:36 PM Reply
Had to replace rams on both sides.
