Old    Nacho (denverd1)      Join Date: May 2004       06-19-2014, 9:48 AM Reply
Been playing around with ballast setup and can't seem to get it dialed in just yet. riding goofy, got 1100 in starboard locker, ski locker sac (est 500 lbs), 300 lbs of lead on starboard bow seat. I've got another 750 I was going to put on the seat behind the driver.
ideal speed is the big question. rode it from 10 up to 12.5 and couldn't seem to get the right push. anyone surfing a 230 and have it setup right?
also, my platform is screwing up the wave a bit. whats the fix?
Old    Jack Henry (racer808)      Join Date: Jan 2013       06-19-2014, 11:08 AM Reply
Fresh Air Exhaust sells platform risers that gets it a little higher so it doesn't mess with the wave. Could probably make some yourself too
Old    Nacho (denverd1)      Join Date: May 2004       06-19-2014, 11:30 AM Reply
Thanks Jack, good to know. The transom is molded around the platform, it seems. not sure if I can move it up without really changing things, but I'll look into it.
Old    Jack Henry (racer808)      Join Date: Jan 2013       06-19-2014, 12:56 PM Reply
The ones Larry at fresh air told me about go under the platform to where ever it bolts to the brackets, if that makes any sense.
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       06-19-2014, 2:33 PM Reply
I surf my 2003 230. 750 in the locker, 600 tube sac on the seat, 500 under floor locker full. Gives a nice clean wave, able to go without the rope no problem.
Old    Nacho (denverd1)      Join Date: May 2004       06-19-2014, 3:23 PM Reply
I have to look but I think have fiberglass that extends out over the platform, preventing me from raising it.
so you don't fill the opposite side at all? I had about 150-200 lbs in there thinking that if the entire boat were further in the water, it would help push a bit more. sounds like thats not ideal.
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       06-19-2014, 3:29 PM Reply
No weight in the non surf side. Even moving 1 body (200lbs) from non surf side, makes a difference. I haven't tested any bow weight yet...
Old    Nacho (denverd1)      Join Date: May 2004       06-19-2014, 3:36 PM Reply
sweet boat Noah.
what speed?
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       06-19-2014, 6:18 PM Reply
Honestly I don't know. We go by rpm and it differs day to day. I try to go as slow as the wake will still stay clean. No perfect pass yet
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       06-19-2014, 7:17 PM Reply
Here is a short clip of the goofy side wave.
 video GOPR0286_zpsec9bd2df.mp4
Old    Adrian (Wet2Ward)      Join Date: Mar 2010       06-20-2014, 12:56 PM Reply
I run with 1100 lbs in surf side and fill the center 500 lbs full, no weight on non surf side, and make sure you are running in at least 10 feet of water. I am 215 lbs body weight and can surf easily without rope and about 6-10 feet from platform. I have also relocated my batteries to get the bag further to the back of the boat, this seems to make a difference, also if you can have someone sit on the surf side on the sundeck with feet hanging over, that helps also. Make sure all others in the boat are sitting on surf side if possible, a couple up front is fine. I run at 10.6 to 10.8 mph.
Good Luck
Old    Adrian (Wet2Ward)      Join Date: Mar 2010       06-20-2014, 1:00 PM Reply
I went with the Hydrophase Ridesteady speed control sysetm and am really happy with ir and the service I received from Justin at Ridesteady. Their web site is: http://www.hydrophase.com/ridesteady
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       06-20-2014, 5:09 PM Reply
Without hijacking too much:
Looks like a good unit with a lot of features. Did you install yourself?
Thanks for the recommendation.
Old    Sue (malibu)      Join Date: Sep 2004       06-21-2014, 1:20 PM Reply
My boat is a 2011 Supreme V212 we load it with around 1400lbs of ballast. It came with a huge platform that screwed up the wake. We put a surf platform on it, just like the one that comes on a V226. Then we had aluminum brackets made at a jet boat shop that raised the platform 4 1/2". Here is a picture of the brackets. Installing a smaller platform and raising it really improved our wake.
Old    Nacho (denverd1)      Join Date: May 2004       06-22-2014, 9:40 PM Reply
Had an extra couple people in the boat this weekend and the wave was huge! just need a little more weight. Got a 750 I'll start putting on the seat.
Sue, thanks for posting that pic. I'll look into raising mine a few inches.
adrian, v230?
Old    Sue (malibu)      Join Date: Sep 2004       06-23-2014, 8:09 AM Reply
Nacho, your welcome. At the West Coast Open I rode behind two V230's that had dialed waves. One was Frank Wolters and the other was Mike Clemets both have sons that compete in the comps Chris and Hunter. Frank is on this forum quite a bit. I'm sure he would tell you how he has his set up.
Old    Nacho (denverd1)      Join Date: May 2004       06-23-2014, 3:08 PM Reply
Thanks sue! I'll get in touch with Frank and see how his is setup.
Also I noticed the thru-hull for the bilge exit is right at the water line when I've got the starboard side weighted. Do I need to add a check valve to that line? Didn't notice a whole lot of water coming in
Old    PM (jetskiprosx)      Join Date: Aug 2004       06-23-2014, 7:35 PM Reply
Our setup in these pics is as follows:
-750 rear
-500 on seat
-500 mid ship (ski locker)
-200 bow
-1000 in people on surf side and rear (dont all fit on surf side)Name:  uploadfromtaptalk1403573707894.jpg
Size:  15.5 KBName:  uploadfromtaptalk1403573723544.jpg
We've found that 200-300lbs. in the bow really helps the surf wave by extending the pocket.
Old    Brent (Brent44)      Join Date: Apr 2013       06-27-2014, 1:34 AM Reply
Hello, we all surf regular so I can't say this works on the goofy.
1100 surf side locker
750 surf side floor
400 surf side seat
400 rear seat nearest surf side.
This set up has good push, but to get phenomenal push you need at least 1, 200 lb person in the observers seat, I don't get why putting some in the bow locker doesn't do the same, but it doesn't. I do not fill the bow locker, yes it does extend the pocket a bit, but you lose some push, it's just not needed.
Old    Brent (Brent44)      Join Date: Apr 2013       06-27-2014, 1:36 AM Reply
Oh yeah, speed... 10.5 via gps
Old    Nacho (denverd1)      Join Date: May 2004       06-27-2014, 12:44 PM Reply
Thanks Brent. Would love to see a pic of you wave if you have one handy. so thats 2650 all in the corner or as close to the corner as you can get it, plus your observer.
I'll snap some pics of mine this weekend. Last weekend we were running 1100 in locker + 750 on seat. 500 in center locker + 250 in lead in the bow. Had 5 people in the boat. Had some nice push and a fairly long pocket.
Old    Brent (Brent44)      Join Date: Apr 2013       07-01-2014, 10:32 PM Reply
Nacho,
Sorry it took me so long to get back with you, have been away. I'll look for some pics, but I have never taken any just to show wave height and length, I will say though you can't see push in pics. I can make a great looking wave with just OK push, I can make the wave look just about the same with the set up I described to you and have incredible push. Anyway, I'll try and find one that is the best representation of my wave. The port quarter rub rail (surf side) is about 2 inches below the waterline when not making way.
Brent
Old    Nacho (denverd1)      Join Date: May 2004       07-08-2014, 2:26 PM Reply
cool! would love to see it.
so, thats no bow weight? I know you said no center locker. Im guessing no, but anything in bow on surf side?
Old     (sandm01)      Join Date: May 2010       07-09-2014, 6:40 AM Reply
sue..
those platform brackets look nice. glad to see you aren't settling for a stock boat
Old    Sue (malibu)      Join Date: Sep 2004       07-10-2014, 3:57 PM Reply
Originally Posted by sandm01 View Post
sue..
Thanks Scott! They make a big difference, keeping the swim deck out of the surf wave. Now what to do with the original giant swim deck that came with the boat. Oh well. I miss surfing with you guys behind the Tige.
Old     (sandm01)      Join Date: May 2010       07-11-2014, 6:42 AM Reply
ya, we miss idaho as well. it's not the same here.. joe ever pick up a van for camping? figured you guys would be all over the pac nw this summer...
you could always turn the platform into a picnic table
Old    Nacho (denverd1)      Join Date: May 2004       07-18-2014, 3:02 PM Reply
another question for you port side riders. My bilge pump is mounted on starboard side about 16" from the transom. If listing to the port side, I end up with a good bit of water in bilge before the pump comes on. So belt and pulleys start getting wet, engine whines, etc. Can I relocate it further back in the center? I saw the rudder in there and can't interfere with that. Do you reloc the bilge pump somewhere else?
Old    Adrian (Wet2Ward)      Join Date: Mar 2010       07-29-2014, 4:21 PM Reply
Yes, I did install it myself, it comes with good instructions and a basic knowledge of electrical and mechanical will serve you well. Justin as Ridesteady is always a phone call away as well!
Old    Adrian (Wet2Ward)      Join Date: Mar 2010       07-29-2014, 4:28 PM Reply
I have not moved my platform up, It does touch the water just a bit, but properly weighted the wave is clean and big!
Old    Barmac (scott)      Join Date: Feb 2010       08-10-2014, 11:32 PM Reply
I put a 1100 in the back of my V230 last month filled it up and the center ballast. had no problem surfing without a rope. I weigh about 215lbs. I feel I need to add some more weight up front to stretch the wake a little more.
Old     (Farmermunn)      Join Date: Aug 2014       08-14-2014, 12:04 PM Reply
I have a 215, which I'm not sure if the 230 has the same transom or not, but I created my own "surf gate" that I think helped a lot. You can check it out here: http://http://www.wakeworld.com/foru...d.php?t=803045
Old    Ryan (RyanC)      Join Date: Apr 2014       08-14-2014, 12:26 PM Reply
What size and type of board are you riding scott? I am having trouble going ropeless being my v230 with 1100s except for right behind the boat.
I am building a wood surf gate as well but won't be able to use it for a few weeks. I will post pictures/videos with the results.
Old    Adrian (Wet2Ward)      Join Date: Mar 2010       09-19-2014, 2:18 PM Reply
adrian, v230?
Sorry, just noticed you asked me if mine is a v230, and yes it is. I am just planning to raise my platform and add Puck board plastic to the underside to get rid of the lip.
Old    Nacho (denverd1)      Join Date: May 2004       09-29-2014, 4:02 PM Reply
lifted my platform a few inches. Also experimenting with a surfgate system for my 230.
