Old     (delitev)      Join Date: May 2014       06-04-2014, 10:24 AM Reply
What speed are you surfing at and what is your weight configuration
Old    Matt (duramat)      Join Date: Feb 2008       06-05-2014, 7:02 PM Reply
What year?
Old     (delitev)      Join Date: May 2014       06-05-2014, 8:57 PM Reply
2002 hurricane
Old    Kendall Burks (kendallb)      Join Date: Aug 2013       06-07-2014, 3:36 PM Reply
I run 10.9.
Old    Corson Piper (piper907)      Join Date: Dec 2011       06-08-2014, 6:54 PM Reply
11.5mph... 1800lbs in the port rear corner, 200lbs in the center (stock), 750lbs on the port side in the bow, 300lbs in the center of the bow. Switchblade on 5, trim tab at 50%.
Old    J Arthur (JArthurSquid)      Join Date: Jul 2013       06-12-2014, 8:15 AM Reply
10.4 mph seems best. I put 1,000lbs in the back corner and 300lbs under the side seat. Then I put ~ 200lbs in the opposite corner to get more boat in the water (use an iPhone app to make sure we are at 6 degree tilt).
Nothing in the bow -- just use the trim tab to clean it up.
