Old    Eric Scott (phillywakeboarder)      Join Date: Sep 2008       05-27-2014, 1:15 PM Reply
So this weekend I mistakenly blasted a pair of my 650's with a 1kHz tone while tuning my system. (I thought I had disconnected the rca cables to the amp that powers the 650's but I didn't.) One survived, one did not. I've been running 150 watts to each speaker, but now, after this, I'm wondering if it's too much. They sound great on the 150 watts (well, at least they did) but now I'm wondering if I should move them somewhere else (once I get another one) and get a pair of 8 inch speakers that are rated for more power. So . . . how much do you guys send to your 650's? I'm just wondering whether this was just an isolated incident or if I'll eventually fry the replacement and the one that survived.
Old    David (DavidAnalog)      Join Date: Sep 2013       05-27-2014, 1:33 PM Reply
Here is the bottom line....you NEVER, EVER send a 0 dB sine wave to a speaker with any amount of power. Speaker failure is expected. It's completely different than music power. So don't repeat that particular mistake and you shouldn't have an issue going forward.
A sine wave test tone is only to determine the maximum limitation of the electronics. It cannot be used for system tuning beyond that. A speaker should not see a sine wave.
Old    Eric Scott (phillywakeboarder)      Join Date: Sep 2008       05-27-2014, 1:42 PM Reply
Thanks David! I guess I should consider myself lucky that one survived, along with my eardrums . . . .
Old    TigeMike (chpthril)      Join Date: Oct 2007       05-27-2014, 3:03 PM Reply
Yep, 150W rms is golden to an XS-650, I would make a change
Old    Ryan Bush (ryanbush11)      Join Date: May 2003       05-28-2014, 9:00 AM Reply
I'm running 150 watts to 8 of them and after 4 years they are all 8 perfect!
Old    Ryan (Wakesounds)      Join Date: May 2011       06-02-2014, 2:09 PM Reply
What did it do to the speaker? (ie how do you know its a gonner)
Old    Nikolas Dramountanis (Greeko)      Join Date: May 2013       06-06-2014, 9:56 AM Reply
I'm sending 225 WRMS with engine on and 195 with engine off to each xs-650....They sound so magical!
Old    Eric Scott (phillywakeboarder)      Join Date: Sep 2008       06-06-2014, 10:49 AM Reply
It's half as loud as it should be, up to 50% volume, then it cuts out and makes the other speaker on the amp cut out. Moved the speaker and the problem moved with it. Wetsounds hooked me up with a new single for a decent price.
Old    Ryan (Wakesounds)      Join Date: May 2011       06-06-2014, 2:32 PM Reply
Did they say what would cause the volume to only play 50%? People can correct me, but I thought if a speaker was fried then it would either not work at all...or play noticeably distorted sound?
