Old    Mike (Salister)      Join Date: Nov 2013       05-26-2014, 10:46 PM Reply
Anyone know a good packing for your packing nuts? I need new cause it leaks almost as fast as the bilge pumps it. I got the old out, and measured them, they're 3/16 thick, only had 2 rings. I am thinking I could put three back in. Just I dont know what kind I should get, or where to get them. Any in site would be appreciated. 92 sanger DD
Old    Brian George (BGeorge01)      Join Date: May 2014       05-27-2014, 6:35 AM Reply
Skidim.com is where I bought mine.
http://www.skidim.com/prodinfo.asp?number=GFO3/16X24
http://www.skidim.com/prodinfo.asp?number=PR18X17
...Just a couple
Old    Trayson Harmon (trayson)      Join Date: May 2013       05-27-2014, 2:06 PM Reply
I just tightened my prop shaft nuts. But for my rudder packing, I went with the Gore tex packing rope as it is a pita to pull the gas tank for access to the rudder and I won't have to service the Gore tex as much. I will be using it on the prop when I do change it.
Old    Rick H (blastmaster)      Join Date: Aug 2001       05-28-2014, 1:30 PM Reply
Old school wax rope is available at any marine shop or West Marine if there is one near you. If not order from Overtons or Skidim. I have a 96 Sanger and only have changed the packing a couple of times ever. Over tightening causes the wax to heat up and melt and then it is no good any longer and leaks. DONT Over tighten. The rope packing is inexpensive.
