Old    Tom Yokoi (countryguy1717)      Join Date: May 2013       05-26-2014, 5:53 PM Reply
Anyone done it? I was thinking of pd the purple and black side of the hull, but I'd have to take the decals off, which I'm sure would show up from fading if the pd didn't work out.
From what I read people thought that the pd would peel off from the water But I pd a stencil the other day and it held up fine on sat on the river.
I'm jusy not sure how to do it. Because if you leave the masking tape on for multiple coats itll peel off when you take the tape off. I guess tape it off spray one heavy coat down and take the tape off before it dries
Old    Tony (T_A)      Join Date: Feb 2013       05-26-2014, 6:02 PM Reply
More likely to cause problems further back where water will be dragging across it while underway
Old    Tom (boardjnky4)      Join Date: Dec 2011       05-26-2014, 6:36 PM Reply
Research the taping off, essentially you have to do 5-6 coats back to back without letting it dry them take the tape off immediately. Will probably look cool, worth a shot for the cost.
Old    Brian George (BGeorge01)      Join Date: May 2014       05-26-2014, 7:36 PM Reply
I say do it! That stuff is strong, I don't see the water tearing it off. I have friends up north that pd their cars in the winter and they don't have any problems.
Old    Jordan Maxymek (Jmaxymek)      Join Date: Feb 2012       05-26-2014, 9:18 PM Reply
I'm gonna disagree here, I've done a lot of plastidipping and I don't think it'll hold up under the amount of water you'll have going over it. As far as the tape issue, you do everywhere that isn't near the tape with however many coats you want to do, THEN get near the tape and do a coat or two gently, then a heavy coat to match up with the rest and peel before it's dry.
Old    Detox (bass10after)      Join Date: Feb 2010       05-26-2014, 11:17 PM Reply
plastidip the bottom right at the v and see how it does. water pressure is pretty intense. I'd like to think that it would work, but have a feeling that anything getting blasted by water at 40mph isn't going to hold up very good. I'd imagine a clean hull and prep is key here
Old    William Burell (williamburell)      Join Date: Sep 2011       05-27-2014, 5:29 AM Reply
Don't think its going to work man. Wish I felt better about it for you but don't see it happening. The problem with this application is essentially the greatness of plastidip which is that it can be pulled off. I did my tower in PD and it has held up great but it will get knicked up and needs to be attended to. I think it would be great for a bit but the first small tear you get its going to balloon with water pressure and peel. Try it out and let us know but I feel like you are going to be wasting your time.
Old    Tom Yokoi (countryguy1717)      Join Date: May 2013       05-27-2014, 10:22 AM Reply
The area of the stencil is below the water line. I'll try a few more and test it out
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       05-27-2014, 10:34 AM Reply
I found this out on the interwebs -!!
