Old     (RideGull)      Join Date: Apr 2012       05-23-2014, 7:12 PM Reply
I tried to find some reviews on this product, but was unsuccessful.
Does anyone have this installed on their boat to fill extra ballast instead of using classic tsunami pumps?
I'm thinking about adding this to a boat to make filling a bow walk thru sac easier.
http://www.wake-worx.com
Old    Russ Weber (Boonejeepin)      Join Date: Oct 2012       05-23-2014, 8:37 PM Reply
I don't see any reason that it would not work very well. It is basically the same as most factory installed reversible pump systems with a quick disconnect hose. Tried and true components arranged in a convenient way.
Old    Surf Addict (Desi) (phathom)      Join Date: Jun 2013       05-24-2014, 12:03 AM Reply
It looks a lot cleaner than throwing a pump over the side. I'm also assuming you wouldn't have any priming issues since it's hooked up to a through hull.
If you have to put a walk through sack in and can't plumb it all in, I'd say this would be a good option to clean up the process and add some convenience.
Old    Russ Weber (Boonejeepin)      Join Date: Oct 2012       05-24-2014, 12:27 PM Reply
Downside when compared to over the side style pump would be adored. 600gph (or whatever it is) vs 1100gph.
Although, convenience would be a deciding factor for me.
Old    Nick in the TC (nick_in_ssp)      Join Date: Aug 2006       05-24-2014, 5:28 PM Reply
I did that years ago. Works great for surf sacs and a sac in the bow.
Old    Timmy! (timmyb)      Join Date: Apr 2007       05-25-2014, 8:23 AM Reply
Heck, I was more interested in this Mussel Mast_R device that filters the water before going into the ballast bags.
http://www.wake-worx.com/Mussel_Mast_R.html
Old    Tom (boardjnky4)      Join Date: Dec 2011       05-25-2014, 8:50 AM Reply
You can probably build that yourself pretty easily too.
Old    Mikeski (mikeski)      Join Date: Aug 2003       05-25-2014, 8:00 PM Reply
I have a jabsco ballast puppy under the bow with a switch under the dash. The hose has about 8' of slack so I can fill a sack anywhere in the boat. Works pretty well but I needed to add a valve on the end so the water in the hose did not leak into the storage compartment.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       05-26-2014, 7:37 AM Reply
I've never used that system, but my primary criticism just on design is that it uses those fly high quick connect fittings. Everyone who has ever hand filled a bag with a tsunami pump knows that the hose pops out of that fitting at the least opportune time. and that's just with one fitting. Now you are going to have two of them (one on either end of the hose). I'd prefer to see a flo rite fitting that can be locked when in service.
Old    Tom (boardjnky4)      Join Date: Dec 2011       05-27-2014, 7:22 AM Reply
Agreed
Old    Ryan (ryanw209)      Join Date: Jan 2010       05-27-2014, 10:01 AM Reply
I have a buddy that got one and never put it in his boat. I'm sure he will sell it if your interested. PM me if you want more info
Old    David Williams (wakeworld)      Join Date: Jan 1997       05-27-2014, 2:49 PM Reply
I had one on my previous boat and it worked great. I especially liked the hose attachment that you can use to clean out the bottom of your boat. Great idea.
Old     (RideGull)      Join Date: Apr 2012       06-10-2014, 2:23 PM Reply
I plan on getting those as well. But since I'm going to have a total of 6 through-hull jabsco pumps, i dont know where i would be able to fit those mussel mastrs.
Definitely a neccessity though since my home lake has zebra mussels and cleaning ballast is a huge pain
