Old    Ross (CenTex)      Join Date: May 2014       05-23-2014, 9:46 AM Reply
I have a 2000 Moomba Kamberra with the Indmar 350. The prop is dinged up and I'm interested in finding a new one with a bit more pitch for the extra weight of my ballast and for a better hole shot. From my research I've found it has a 1 1/8" shaft. Where is a good place to get a new prop, can anyone tell me what I need to look for in the sizes or the prop and what pitch should I go with. We wakeboard and I have about 2100 pounds of ballast that I can run in the boat.
Old    Connor (iShredSAN)      Join Date: Apr 2012       05-23-2014, 10:03 AM Reply
Call Nettle Props here in Austin. I always get my props repaired and purchase new ones through them. They should be able to help you out with which one you need for your specific boat, weight, etc...
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-23-2014, 10:09 AM Reply
Wakemakers.....
http://www.wakemakers.com/props
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-23-2014, 10:12 AM Reply
ActiveWake
http://www.activewake.com/wakeboard-boats/props.html
Old    Spencer (spencerwm)      Join Date: Feb 2009       05-23-2014, 10:13 AM Reply
The 2000 Moomba Kamberra either came with a 14x16 or 14x18 and should have an 1-1/8" shaft.
I would suggest decreasing the pitch to 14.25" in order to get the low end pulling power. Check out the Acme 1433 (14" x 14.25") or the OJ 466 (14.25" x 14").
Old    Ross (CenTex)      Join Date: May 2014       05-23-2014, 10:41 AM Reply
Thank y'all for the help!!
