Old    Tyler Conley (TC_Mastercraf_X5)      Join Date: Feb 2013       05-22-2014, 11:23 AM Reply
So my 06 Wakesetter VLX turns fine both direction at low speeds; however, at 20+ mph it's a real beast to turn it to the left. However, still turns with a finger to the right... Any thoughts on what might be causing this? The steering cable was just replaced two years ago by a shop in central IA.
Old    Charlie Zulu (Pad1Tai)      Join Date: Jan 2013       05-22-2014, 12:02 PM Reply
I'd grease the rudder box... there is a zerk fitting on it..
Old    Jack Henry (racer808)      Join Date: Jan 2013       05-22-2014, 12:25 PM Reply
Mine was doing the same thing, new cable made it right as rain
Old    William Burell (williamburell)      Join Date: Sep 2011       05-22-2014, 12:31 PM Reply
I would unhook the cable and make sure the rudder moves smoothly. If it does replace the cable. Greasing the cable is more to keep out water to prevent corrosion. Once the cable gets stiff its usually a lost cause.
Old    Jack Henry (racer808)      Join Date: Jan 2013       05-22-2014, 2:33 PM Reply
Do not grease cable but do grease rudder box. There are zerk fittings as stated above. 2-3 pumps in each is plenty.
Old    Tyler Conley (TC_Mastercraf_X5)      Join Date: Feb 2013       05-23-2014, 7:32 AM Reply
Has anyone played with the trim tab on the rudder? Potentially moving it left a bit.to start with see what difference it makes? is it because of prop torque ?
