Old    Jut (robertsjut)      Join Date: Jul 2009       05-21-2014, 8:55 AM Reply
Hey guys,
I just purchased about a month ago a 07 Supreme Black and Red. It has visual water spots on the black that I what to remove. What do I need to do to get these removed? What products?
I have purchased the Stimulus Package from Boat Bling. To help keep them away in the future!
Old    Ben R (brichter14)      Join Date: Jul 2010       05-21-2014, 9:02 AM Reply
1/3 vinegar. 1/3 windex. 1/3 water.
Old    Zack Bale (Fourspeednup)      Join Date: Apr 2010       05-21-2014, 9:15 AM Reply
Hot Sauce should remove the majority but anything that is etched in to the gel will need acid or polish/compound to remove. Keep a real good coat of wax on the black areas to minimize future issues.
If you go the acid route I'd suggest diluting muriatic (pool) acid with plenty of water in a sprayer and using plenty of fresh water to flush it off afterward.
Thanks for the business! Any questions don't hesitate to ask
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-21-2014, 9:23 AM Reply
Hey Jut -
It looks like you are local to PDX? I have a gallon of Auto Magic Hard Water Spot Remover. It works very well. If you want to bring a spray bottle by my house, I would fill you up and you can try it. As Zack said above, it depends on how deep your water spots are. I have heard good thing about his products, but if you want to try this first, feel free to hit me up.
Either way you are going to have to put in some elbow grease. Next step would be to get some compound and polish her down if you know what you are doing with a buffer.
After you get it all cleaned up, give it a good coat of wax and as long as you wipe it down good after each use, you should be good to go.
Old    Jut (robertsjut)      Join Date: Jul 2009       05-22-2014, 7:23 AM Reply
Hey guys thanks for the replies and ideas.
Diggs I'm about 1hr south of PDX but will hit you up next time up there.
Here is a better picture of the water spots after I removed the old boat numbers.
I'm pretty sure the only way to get them off is going to be a good waxing.... What product and applicant/removal process is going to work best?
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-22-2014, 8:00 AM Reply
A "good waxing" will not get those off. If you are good with a buffer you can use a good compound (3M or similar) and buff down the whole thing and then wax it up. The water spot remover should put a pretty good dent in it too, but as I said you will have to put in some elbow grease and be prepared to have some sore arms!!!
You should have it looking like new once you are done...
Old     (jbkriss)      Join Date: Mar 2011       05-22-2014, 8:46 AM Reply
I like the Hot Sauce too. If that doesn't get it all off, try cleaning with a a mixture of .3 CLR/Limeaway, .3 vinegar, .3 water. Then if that doesn't get it all off, go to the buffer. Just trying to save you some time if possible...
Old    Surf Addict (Desi) (phathom)      Join Date: Jun 2013       05-22-2014, 10:46 PM Reply
As stated above, vinegar. To get water spots off, I tend to use just a simple vinegar and water mix, about 3 parts vinegar to 1 part water in a spray bottle. It works pretty well, is cheap and always readily available.
Old    Chattwake (chattwake)      Join Date: Jan 2010       05-23-2014, 5:18 AM Reply
That 3m compound is awesome. What's the specific name of the gel polish they sell?
Old    Markj (markj)      Join Date: Apr 2005       05-23-2014, 11:57 AM Reply
The big secret with black is just to stay on top of it. Don't ever put it away wet and try to use the boat bling type products when you wipe it down.
Old    Eric Scott (phillywakeboarder)      Join Date: Sep 2008       05-23-2014, 12:06 PM Reply
This stuff will have those marks off in about 10 seconds. Wear rubber gloves. Do not breathe the fumes.
