Old     (MUNS)      Join Date: Jan 2012       05-12-2014, 6:10 PM Reply
Hey Wakeworld
I need to order a drive plate but I'm not sure which one I need. Its an 05 21v
Old     (phathom)      Join Date: Jun 2013       05-12-2014, 11:12 PM Reply
What engine and transmission do you have in it?
And by drive plate, you are referring to the plate on the back of the engine that links up to the transmission right? The one with all the springs and such on it?
Old     (MUNS)      Join Date: Jan 2012       05-13-2014, 5:32 PM Reply
Yes the one with the springs and such, some call it a damper plate as well
Engine is an indmar assult, there were 2 different engines. The 325 and 340 I think? I dont know which one I have for sure cause it doesnt say anywhere but I think its probably the 325. And as for transmission, from what I read on indmar if the boat has a walters v drive ( which it does ) than it has the zf hurth inline.
Old     (phathom)      Join Date: Jun 2013       05-13-2014, 5:47 PM Reply
This should be it. It says it's for small block gm 5.0 and 5.7 with a hurth transmission. 26 splines. Count your splines but I think it's the one.
http://www.skidim.com/prodinfo.asp?number=97596
Old     (MUNS)      Join Date: Jan 2012       05-17-2014, 7:52 AM Reply
awesome! Thank you kindly!
Old     (imscarlet)      Join Date: Mar 2008       05-18-2014, 2:57 PM Reply
Try the dealer, should be more cost-effective from them and Indmar now use the same plate for all engines whether its the big block, small block or the LSA
