Old    Brent H (BlitzedVLX)      Join Date: Feb 2011       04-11-2014, 3:03 PM Reply
Found out today that the 2014 AJ boots I pciked up are not really compatible with the 2010 system binding that has the bar going across the middle. I was told by my dealer that I would be able to use the "retro" kit which consists of a couple pads to even it out and make it flat. I was wondering if anyone has rode with this setup using the new boots on the old bindings.
Old    Kyle Henry (KyShredZ)      Join Date: Jan 2014       04-12-2014, 2:24 PM Reply
I just picked u the 2014 Webb boots w/ 2014 Systems only because I was told here on WW that the older bindings were not compatible with new boots. Originally was going to get Webbs with older systems. May want to consider 2014 bindings.
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       04-14-2014, 12:34 AM Reply
if you get this "retro" kit then you will be that much higher off the board. plus, the pads better be pretty solid, otherwise your going to feel the bar in the middle on big impacts and more so over time as the "pads" get broken in. Id go for the new systems.
with that said i have never rode te systems, just adding my 2 cents.
Old    Brent H (BlitzedVLX)      Join Date: Feb 2011       04-15-2014, 7:48 AM Reply
I went ahead and ordered the 2014 pro systems. I also feel that the fit of the 2014 Aj is slightly larger than that of the 2013 Aj
Old    Mike North Carolina (MIKEnNC)      Join Date: Nov 2012       04-15-2014, 7:57 AM Reply
the pads suck and are tall and cheap, I don't like them at all
