Old     (WakeHilton)      Join Date: Jul 2013       03-31-2014, 7:40 PM Reply
I've got some boat lift questions. I'm doing some research and trying to figure out which boat lift to go with. I've got a Wakesetter Mxz22. I beleive the dry weight is right at about 4400. So I'm looking at possibly a 6,000 3/4 hp gear driven or 8,000 lb 1hp lift. (Probably gonna go with the 8000) 10' wide cradle. I'm wondering if it's worth it do do the dual drive where there is one motor on each side or the regular center mount? The advantage I see with the dual drive is you have more room for the tower when it's lifted and it's probably faster. Wondering if it's worth spending the xtra $ for an aluminum cradle and ss cables. The river we are at is brackish. What lifts are y'all using for your heavy/wide wakeboats? Thanks for any input.
Old     (okwakebdr)      Join Date: Jul 2005       04-01-2014, 6:32 AM Reply
2x6000 lbs would be my choice - especially on the SBR. Lifting the boat up higher has a big advantage (if the water level comes up and to help keep the boat out of the sun, rain, and dirt).
On the SBR (brackish) - I wouldn't even consider anything other than aluminum.
Old     (biggator)      Join Date: Jul 2010       04-01-2014, 6:40 AM Reply
How about something like a HydroHoist? I've had mine for almost 9 years.. they're fantastic.
Old     (dejoeco)      Join Date: Apr 2003       04-01-2014, 7:54 AM Reply
I had a stainless cable break on me. My boat lift guy says he uses nothing but galvanized unless the customer specs something different. He says the galvanized is not as prone to failure when a strand begins to go as with stainless cables. It is scary when a line pops as you are lowering you baby into the water.
