Old    Jordan Haugen (jordanh)      Join Date: Feb 2013       03-31-2014, 1:33 PM Reply
I have a cheaper equilizer that does not have a USB port on the back. Just audio inputs. I am wanting to get a usb hooked up so I can use a bluetooth dongle. Is this what I need?
http://www.crutchfield.com/S-yDIfDQZ...-CCAUSBAV.html
Old    Jordan Haugen (jordanh)      Join Date: Feb 2013       03-31-2014, 1:40 PM Reply
http://www.polyplanar.com/product/ac...xtension-cable
Or better yet this? Will this let me go from female usb to the audio inputs on the back of the equilizer
Old    Detox (bass10after)      Join Date: Feb 2010       03-31-2014, 2:02 PM Reply
those are just extension cables to relocate an existing usb to a new spot, not add one that isn't existing.. your best bet is to get a bluetooth adapter that goes to rca cables instead and keep your eq. wetsounds makes a nice one and there are other inexpensive options out there as well. if you want to change the eq wetsounds just released one today with built in bluetooth so you will have three choices on how to get a music signal.
Old    Tom (boardjnky4)      Join Date: Dec 2011       03-31-2014, 2:19 PM Reply
If you want bluetooth, just get the Wetsounds bluetooth adapter. It plugs in via AUX (which can be split into RCA easily with an adapter cable).
https://wetsounds.com/pages/products/WW-VC-BT.html
Old    Jordan Haugen (jordanh)      Join Date: Feb 2013       03-31-2014, 3:20 PM Reply
Thanks for all the help guys. I think I'll hold off on he bluetooth until i can upgrade to the new 420. I'm a complete rookie with audio equipment and didn't realize you could get a bluetooth adapter that plugs directly into the audio inputs. I'll also look into that
Old    David (99Bison)      Join Date: Sep 2012       03-31-2014, 3:31 PM Reply
Another option is to go wifi instead of Bluetooth, a few options out there, 25-75$.
Old    Scott (scottb7)      Join Date: Oct 2012       03-31-2014, 5:20 PM Reply
can someone post a link or two to a wifi solution?
Old    David (99Bison)      Join Date: Sep 2012       03-31-2014, 5:43 PM Reply
Here's a couple:
http://www.amazon.com/dp/B00EZWVZ44/...I15OU0LKXPV54M
http://www.amazon.com/dp/B00I0Z427E/...I2ZB5WI1B60RBK
- I bought one of these to try out a month ago. Seems to work just fine in my limited testing of it (2-3 hours in the garage).
And an Apple TV, just using air play for audio. I also saw this for $75 somewhere last week.
Old    Scott (scottb7)      Join Date: Oct 2012       03-31-2014, 7:06 PM Reply
ok, i am stupid. can people please explain how this would work??....i am very interested in avoiding blue tooth. first of all i have android. so looks like the 2nd one listed above would be the ticket. so obviously i would send signal to this device and plug that device into the stereo. but how? the device receives wifi. but how would it work when not on my home network? does your phone have to be able to be a wifi hotspot? is that the ticket? if not then it won't work???
