Old     (ride152)      Join Date: Nov 2005       03-28-2014, 4:05 PM Reply
Just ordered a full WS package including the EQ.
Looking for recommendations on where to mount it. Seems under dash is common, but not sure if the aluminum sheet under my dash will support it well.
I have a 2010 Air.
Anyone put it in the small compartment to the left of the steering wheel?
If under dash, is the bracket necessary? Concerned about leg room.
Thanks!!
Old     (chpthril)      Join Date: Oct 2007       03-28-2014, 4:41 PM Reply
No issues on a 2012 230
Another 230 with a more permanent install
Old     (jonyb)      Join Date: Nov 2008       03-29-2014, 1:39 PM Reply
You can mount it like Mike mentioned, or add the billet bracket that Wet Sounds just put out for a more finished look. I've done both and they both work well.
Old     (ride152)      Join Date: Nov 2005       03-30-2014, 6:17 AM Reply
Thanks for the responses!
I like the clean look of the EQ mounted near the throttle.
It seems like that might be slightly more convenient to see and use the controls.
Mike, which mounting location did you prefer?
