Old     (cek)      Join Date: Sep 2013       07-07-2014, 9:20 PM Reply
Ok. I have a problem. I bought a SD2 to replace my syn2. I swapped the two and have no power to the SD2. Couldn't figure it out so I swapped back to the syn2 and everything works again. It's running 4 rev10's.. I can't even get the SD2 to power up.
HELP
Old     (Midnightv10)      Join Date: Feb 2012       07-08-2014, 8:44 AM Reply
Did you check the fuses in the amp?
Old     (cek)      Join Date: Sep 2013       07-08-2014, 8:50 AM Reply
Yes. All good.
Old     (Midnightv10)      Join Date: Feb 2012       07-08-2014, 8:57 AM Reply
My only other suggestion (other than the amp may be bad) is to check your remote turn on lead. A few years back I had 3 Fosgate amps with the remote turn on leads wired straight to the head unit. Wouldn't turn the amps on. I then wired them through a relay and everything worked great.
Old     (cek)      Join Date: Sep 2013       07-08-2014, 9:10 AM Reply
Maybe this is where the problem is (forgive my ignorance I know almost nothing about electrical). My original setup was a syn6 to run the boat speakers and a syn2 to run the tower speakers. I added 2 additional Rev10's to the tower so I upgraded the syn2 to a SD2. The remote power wire is ran from the syn6 remote power to the syn2 remote power and works fine. Is that something I have to change with the SD2?
Old     (Midnightv10)      Join Date: Feb 2012       07-08-2014, 9:43 AM Reply
Not necessarily but that could be the issue. so if I am understanding you right, your remote turn on lead comes from the head unit to the SYN 6 and then is daisy chained over to the other amp? if so, try disconnecting the turn on lead from the 6 and run it over to the SD 2 by itself (leaving the SYN 6 unconnected)
then turn the system on and see If the amp turns on.
IMO the best way to handle the remote turn on leads in a multi amp system is to connect the remote lead coming off the head unit to a relay and then running off the relay over to the amps into a small distribution block and then feeding each amp with a separate lead off the dist block.
Old     (cek)      Join Date: Sep 2013       07-08-2014, 9:57 AM Reply
Ok. I'll try that when I get home. Thank you. What kind of relay are you talking about? Again I know just enough to get into trouble here lol. I do know what a distribution block it though...
Thanks again
Old     (Midnightv10)      Join Date: Feb 2012       07-08-2014, 10:27 AM Reply
Just a regular 5 pin automotive relay.. can pick one up at most any parts store.
http://www.parts-express.com/12-vdc-...m_campaign=pla
wire it like this
Old     (cek)      Join Date: Sep 2013       07-08-2014, 10:35 AM Reply
Wow... Thank you...
Old     (cek)      Join Date: Sep 2013       07-08-2014, 9:27 PM Reply
Got it. It was a chassis fuse. Thanks for the help.
