Old    Bryan Poss (burn229)      Join Date: Nov 2007       03-19-2014, 7:58 PM Reply
I removed the stock rear and upgraded to 1100# wakemakers kit but has anyone tried doing anything to the 500# stock front? Is there room to even upgrade up there?
Old    Art (rallyart)      Join Date: Nov 2006       03-19-2014, 9:48 PM Reply
Maybe you could put in some sacs under the seats like some of the Xstars had but the current front bag fill the space where it's located. Other than that it needs visible bags.
Old    Danny Pacini (dp513)      Join Date: Jul 2011       03-19-2014, 10:51 PM Reply
led in the front will do the trick. hidden and it works well. i know ill be adding a couple hundred lbs to mine.
Old    Ryan (ryanw209)      Join Date: Jan 2010       03-19-2014, 11:18 PM Reply
Yes lead in the front is the best way to go. I am running 750's in back, stock 500 in the front, 400 in lead under the front seats and a SL 600 in the front walkway. If you don't want to go with lead then a bow triangle is the other route.
Old    J (Jmorlan)      Join Date: May 2013       07-14-2014, 10:49 PM Reply
Where do you guys get the lead?
Old    Bwake (bwake)      Join Date: Sep 2009       07-16-2014, 2:57 AM Reply
Mine is melted down rims weights from tyre shops. Put them on a gas stove (outside) and pour the lead into baking tins the size you like. Wrap and all done.
Old    Nacho (denverd1)      Join Date: May 2004       07-16-2014, 7:43 AM Reply
I know it prolly wouldn't fill all the way, but couldn't you put this sack under the seats? got a little lead in mine, just don't want it all in the bow.
