Old     (W5)      Join Date: Apr 2013       03-17-2014, 12:54 PM Reply
If you could modify your existing tab, what would be most beneficial? Longer / Wider / Contoured to the v of your hull ?? What do you think? It looks like you could drill four holes and mount...
Old     (fence_sence)      Join Date: Jul 2008       03-17-2014, 1:58 PM Reply
I've thought about trying a deflector for the FAE. Sort of a "diffuser" to disturb the water flow to the leading edge of the FAE. Probably wouldn't work.
Old     (trayson)      Join Date: May 2013       03-17-2014, 4:16 PM Reply
I would like to add power actuators to mine. I can adjust mine, but isn't not exactly much adjustment nor is it on the fly!
Here's a good view of mine with the platform off.
Old     (Pad1Tai)      Join Date: Jan 2013       03-20-2014, 8:07 AM Reply
I installed lenco tabs on my boat... Pretty easy... But I extended them to 18 inches long... Now I'm adding channels to them..
