Old     (kx250frider617)      Join Date: Aug 2013       02-14-2014, 12:26 PM Reply
I have a 2003 Ram 1500 4x4 that needs a paint job pretty bad. Clear has peeled in areas and chalking up. Now heres the deal. The truck is 11 years old, has 140k miles and I actually recently just installed all new front end components: ball joints, upper control arms, wheel bearings, shocks, inner outer tie rods, cv axles, drilled slotted rotors etc. The truck drives like it is brand new. However, I feel a bad financial decision would be to drop $3k on a truck that isn't even worth more the $7k.
My idea is to try and paint the truck myself with a military grade gillespie coating, They sell a flat 34052 lusterless USMC green color. Does anyone have any experience with this type of paint? My plan is to paint one panel at a time and do the best I can prepping it. I already realize that it won't turn out absolutely perfect, but $150 for two gallons and probably another $100 in materials is a lot better than $3-4k for a professional job.
I am soon to be in the fire academy and actively looking for a fire fighter job so funds are tight and I want to keep this truck until I can afford what I really want.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       02-14-2014, 12:40 PM Reply
This is the perfect time to use Plastic dip!!!!!!!!!!!!!!!!!!!!!!!
Old     (kx250frider617)      Join Date: Aug 2013       02-14-2014, 12:43 PM Reply
That was my first idea but that stuff is illegal in CA in large quantities.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       02-14-2014, 12:45 PM Reply
wrap it?
Old    Justin Nead (hp_inc)      Join Date: Jul 2007       02-14-2014, 1:07 PM Reply sent me plasti-dip by the gallon out here in California. Painted my K-5 for fun. Easy stuff to use. Holds up pretty decent as well. If I recall it was about $60 a gallon.
Old     (kx250frider617)      Join Date: Aug 2013       02-14-2014, 1:08 PM Reply
Originally Posted by hp_inc View Post sent me plasti-dip by the gallon out here in California. Painted my K-5 for fun. Easy stuff to use. Holds up pretty decent as well. If I recall it was about $60 a gallon.
Was this recently? I heard CA got strict about this stuff not too long ago.
Old    Darrel F (95sn)      Join Date: Sep 2005       02-14-2014, 1:38 PM Reply
Get a cheap harbor freight HVLP gun, skuff, mask, shoot.
Old    Justin Nead (hp_inc)      Join Date: Jul 2007       02-14-2014, 1:42 PM Reply
It was last year if I recall.
Old     (kx250frider617)      Join Date: Aug 2013       02-14-2014, 2:16 PM Reply
I forgot to mention, I have already plasti dipped my roof. I had bad clear coat chalking. Well, the dip has started to bubble and lift in those areas. If I were to dip the whole truck, would sanding down the original chalky clear coat prevent lifting while the dip seals and prevents it from spreading? I just don't want my ****ty dodge clear coat to bubble under the dip in areas that look good at the moment.
Old    Tom (boardjnky4)      Join Date: Dec 2011       02-14-2014, 2:20 PM Reply
+1 for plastidip!
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       02-14-2014, 2:37 PM Reply
Here is my two cents as an x-bodyshop guy - everything is about the prep. 90% of how it turns out is going to be about the prep work you are willing to do. Painting any vehicle is harder than it looks as well. Every dent, ding and deep scratch is going to be highlighted when you throw on new paint even if it is flat. You WILL NOT be happy with how it turns out. I am not sure where you live - but there are a number of lower end paint shops that will charge you $300+materials to shoot your rig assuming you paint it the same color as before - so all the jambs do not have to be dealt with.
My advice: watch some youtube videos on body work and most importantly preparation (if you don't already know how to do it) - fix your major issues - get it pained the same color by a low cost (Maaco or Earl Sheib) and pay for the good materials. You could be in and out for $6-700.
Old    Da MOOSE (da_moose)      Join Date: Feb 2004       02-14-2014, 3:58 PM Reply
I just got done sanding My Bro kids Truck,Same proplem
You got to sand alll the bad paint off ,and Spray it with poly fill primer ,then Block it out with 100 grit ,Spay again and then Sand with 220,then 320 ,,,Paint
Then my bro took it to Maaco this week and thay wanted $1200 + to paint,,,I looking for a spray booth now
I painted this car 10 years ago ,,,About $800 for paint and Stuff +$150 for a spray booth ,,,took about 12 hours to paint 2 tone
Old     (kx250frider617)      Join Date: Aug 2013       02-15-2014, 12:38 PM Reply
Thanks for the info. I think Ill just try to get a hold of 5 gallons of plasti dip and spray my truck flat black. No need for prep and if I do want to change my mind later on, it peels off. The question is, will that stuff last a few years or will it start to fade and turn grey?
Old    Sean M (magic)      Join Date: Mar 2002       02-15-2014, 3:50 PM Reply
I coated my car's rims in PalsticDip 3 years a go. Still looks good, no peeling.
Old    Da MOOSE (da_moose)      Join Date: Feb 2004       02-21-2014, 8:29 PM Reply
I don't know what palstic Dip is ,,,But Zero Rust is the best Rust paint I've ever seen,been using it for over 25 years ,has an ok finsh,,,
And a nother cool paint job is use Color Primer,,, I did thay to a van of mine , Two toned it hides all miner body needs intill you have time to fix em
Old    Boarder 42 (jhartt3)      Join Date: Jan 2012       02-22-2014, 5:26 AM Reply
hey shawndoggy you think that vinyl wrap the way that kid did it will work on a boat?
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       02-22-2014, 6:41 AM Reply
why wouldn't it? Seems like to do it right (and to echo phatboypimp) prep would be key... removing the through hulls, cleats, handles, etc would likely make the final product all that much better. Some good info here too:
