Old    Selymon Shahsamand (selshahsamand)      Join Date: Jan 2014       02-07-2014, 9:01 AM Reply
Hey guys picking up a new to me 2011 MB tomcat f21. Has upgraded tower speakers and interior speakers along with upgraded amps. Only thing thats stock still is the sub. Its a 10 mounted directly behind the driver seat. Its being run on a arc audio 600 watt rms amp. I would like to upgrade that to something thats going to give out more bass. Can I cut it open and drop in a JL 12w7 or do i stick with the 10 and go with a 10w7 JL. Thanks for your help in advance!
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       02-07-2014, 9:13 AM Reply
First step would be to seal up the very poorly sealed box that the current sub is in.
Old    Selymon Shahsamand (selshahsamand)      Join Date: Jan 2014       02-07-2014, 9:30 AM Reply
Ok will do. But what sub would be a good upgrade and would cutting open the box to fit a 12 a good idea? Thanks
Old     (WakeDirt)      Join Date: Jun 2011       02-09-2014, 6:23 PM Reply
I wouldn't add a 12 personally, I am in a similar situation and will be doing as SD said above. First: put it on a better amp & seal it. If that isn't "enough" I will be adding 2 more tens under the driver's helm
Old     (ToddWake)      Join Date: Feb 2014       02-09-2014, 6:48 PM Reply
Let me get this straight.
You were in a 4g negative dive with a MIG 28? At what range?
Old     (ToddWake)      Join Date: Feb 2014       02-10-2014, 4:31 PM Reply
"If you were directly above them, how did you see them?"
I was inverted.
Old     (ToddWake)      Join Date: Feb 2014       02-11-2014, 6:59 AM Reply
Negative ghost rider the pattern is full.
Old     (WakeDirt)      Join Date: Jun 2011       02-11-2014, 11:31 AM Reply
Cocaine is a hell of a drug....
