Old    Brad Webb (04outback)      Join Date: Jul 2007       04-02-2015, 10:01 PM Reply
Gonna be towing a 21v. A Long way and am thinking I should fold the tower for the tow.
How should I brace the tower ? Any tips appreciated
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       04-03-2015, 7:11 AM Reply
Not 100% familiar with that tower, but when we hauled our Supersport with a FCT to Florida and back (from Wisconsin) we just removed the speakers / racks, covered the tower with painters tape (keep bugs from hitting the actual tower) and left it up.
Some friends of ours have a VLX and an illusion tower, they made a PVC goalpost to go under and help hold the weight of the tower.
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       04-03-2015, 7:34 AM Reply
Brad
I say leave it up. You can cause more damage down unless you take a lot of precaution.
If you leave it down, I would wrap towels wherever anything can puncture the vinyl or the gelcoat and just make extra sure some bumps won't wiggle those towels loose.
I would take your Z5 down and tow with it up. Put the z5 in the boat upside down and again put towels in any puncture areas or just throw it in the moving van. Every time you fill your gas tank, take a spin on the tower knobs to make sure everything is good. Take a roll of visquine (sp?) and wrap your tower and speakers to keep the bugs off.
Old    Kevin (K_Dubbs)      Join Date: Feb 2015       04-04-2015, 8:54 AM Reply
Agree with recommendations to leave the tower up if possible, remove all the accesories and use tape or plastic wrap on the leading edges to protect from 60+ mph bug strikes. Structurally more sound that way and disturbances from the road will not result in unexpected rubbing or banging on other components/surfaces.
Unless you have a tower down cover that you'd like to leave on while trailering, if thats the case make a couple PCV or wood tower stands (similar to a jack stand) to set the hight to a safe position. Then to make sure it is fully constrained, use some straps or tie downs to hold it snuggly against the stands so it doesn't bounce up. Also watch out for slack and flapping in your cover. Eventually will leave some scuff marks on your gel. I have laid towels between cover and boat before in suspect areas which worked well.
Old    Brad Webb (04outback)      Join Date: Jul 2007       04-05-2015, 5:48 AM Reply
Thanks. I think I'll remove everything off the tower and shrink wrap it.
When I towed it from ny to Louisiana I put a stripe of tape under where the cover contacted the hull and tool speakers off.
Also, I have learned that taking the canvas off z5 helps a ton for wind resistance.
I don't think that if I leave cover on and fold tower down that it would be good for the cover.
I have a spare on the way this week and I'll grab a bunch of shrink wrap.
