Old    Bret Cole (Bret)      Join Date: Nov 2013       01-27-2014, 1:14 AM Reply
So last summer we where up at Tahoe and in the inspection line and when went to show the inspector our ballast one of the pumps wouldn't turn on or work the model is a Jabsco Ballast Puppy 18220-1127 the thing is the original owner replaced the original pump with that one in 2010 does anybody know would could possibly be wrong with it. The boat is a 2004 Ski Supreme Sky Supreme V230.
Old    MCXSTAR (snork)      Join Date: Jun 2007       01-27-2014, 6:26 AM Reply
can you hear if the pump switches on if not disconnect and reconnect or look for a fuse or breaker
Old    Charlie Zulu (Pad1Tai)      Join Date: Jan 2013       01-27-2014, 6:57 AM Reply
It's broke............
After you empty the ballast, always run the pump in the fill direction for a few seconds... A dry pump sometimes will not flip the impeller blades over when dry..
Never had a problem with my 6 jabsco pumps since doing this..
Old    RB (boardman74)      Join Date: Jul 2012       01-27-2014, 8:42 AM Reply
We are going to need a lot more info then you are giving to help you. Did the pump ever work since you got it? Is there power at the pump? The first thing I would do is make sure you have power at the pump.
Old    Dave (bcrider)      Join Date: Apr 2006       01-27-2014, 10:15 AM Reply
Check power, ground. If it runs and no water pumps then you probably need to replace your impeller. Pull it out and connect it to a battery or battery charger to test.
Old    Bret Cole (Bret)      Join Date: Nov 2013       01-27-2014, 1:23 PM Reply
Here it is we bought the boat in august 2012 and we have never used the ballast because before this we had a 1996 Hydrodyne Grand Sport and didn't know that much about ballast and stuff and how it all worked.
Old    RB (boardman74)      Join Date: Jul 2012       01-27-2014, 3:47 PM Reply
So your not sure if the pump ever worked since you had it. First thing is to test for power at the pump. Does the pump turn on, just not pump? If you have power then pull the pump and test right to a power source(battery). If you got nothing the pump is junk. If you don't have power at the pump you are going to have to work upstream till you find where you are losing power. If none of what I am saying makes sense, then you probably need to find a dealer to make the repair. These things can be simple repairs and they can be complicated.
Old    TigeMike (chpthril)      Join Date: Oct 2007       01-27-2014, 7:18 PM Reply
pump needs a ground circuit too, so dont forget that.
