Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-23-2013, 1:07 PM Reply
Can someone tell me what the latest Jabsco Ballast Puppy pump model is because one of the pump's in our boat went out over the summer and I thought i might just get both of the pump's replaced so i would like to know which one of these it is
18220-1121
18220-1123
18220-1127
Old     (tampawake)      Join Date: Mar 2008       12-23-2013, 2:08 PM Reply
Just email or call wakemakers. They will take care of you and are typically the cheapest.
18220-1121
18220-1123
18220-1127
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-23-2013, 2:44 PM Reply
I'm not doing it myself I'm going to get them ordered installed by my mechanic so i just need to know which of these three models is the newest one
18220-1121
18220-1123
18220-1127
Old     (spencerwm)      Join Date: Feb 2009       12-23-2013, 2:50 PM Reply
They are all the same pump. The last four numbers in represent the impeller. Buy a Jabsco Ballast Puppy pump and it will have the green impeller unless it has been on the shelf for two years.
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-23-2013, 3:24 PM Reply
then could someone tell me if i replace the pump that is broken and then put a new impeller in the old one will the speed be the same on both of them.
Old     (BenHolloway)      Join Date: Aug 2012       12-23-2013, 3:36 PM Reply
yup...
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-29-2013, 12:34 AM Reply
then can someone tell me the Jabsco Ballast Puppy model number was 2004, 2005, or 2006 because for 2 years before the previous owner bought the boat the dealer took it to the boat show's in the years 2004, 2005, and 2006 so I don't know when they put the pumps in. Then he put a new pump in there in 2010 because one of the pumps went out and the pump he replaced the broken one with was the Jabsco 18220-1127 so i would like to know what the model number is for the one that he didn't replace so i could know if they are the same pump.
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-29-2013, 12:46 AM Reply
I can't check the pumps myself right know because the boat is at Wayne's upholstery down in Fresno getting reupholstered and it won't be back for a few weeks.
Old     (spencerwm)      Join Date: Feb 2009       12-30-2013, 9:46 AM Reply
They are all the same. Go with a Jabsco 18220-1127 to replace any of them that go bad. That pump will come with the green impeller.
Old     (Bret)      Join Date: Nov 2013 Location: Santa Rosa, CA       12-30-2013, 10:15 AM Reply
Then what if the original pump is a water puppy should I replace it with a ballast puppy so they could be the same speed or are they the same
Old     (BenHolloway)      Join Date: Aug 2012       12-30-2013, 10:39 AM Reply
its the same pump, just a different name... if the pump motor isn't bad, or the housing isn't broken just throw in a new impeller. Wakemakers.com has the impeller you need, or they can sell you a new pump if yours is fried.
