Old    Noah Brown (doubleup16)      Join Date: Sep 2007       12-21-2013, 11:08 PM Reply
I recently bought a 2003 V230. It has the center ballast and worked without trouble the first couple times we had it out. Now it seems to run without pumping fill or drain. I assume it needs a new impeller but I couldn't locate the pump. It sounds like it is under the dash/driver foot area (have a 12" sub blocking most access) but it could be tucked in the locker somewhere.
Anyway, does anyone know where it is typically mounted and what pump it might be?
Old    Chris Dirty (Dmac420sj)      Join Date: Mar 2012       12-22-2013, 7:55 AM Reply
Stock pump is a pos. when they put the sub there they should have relocated the pump. Good luck
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       12-22-2013, 8:55 PM Reply
So I moved the sub out of the way to reveal the pump mounted to the floor. Good news.
I pulled the 4 screws to check on the impeller and found pieces. Bummer, but easily fixed.
So I needed an impeller for a scc DC-206P. I quickly searched and came up with this part number: ACK-1062-10
Ordered it from Here
and will hopefully have it in a couple days.
Old    Noah Brown (doubleup16)      Join Date: Sep 2007       12-22-2013, 9:37 PM Reply
SCC Direct
