Old    David Di Donato (davedidonato90)      Join Date: Mar 2013       11-15-2013, 10:55 AM Reply
just wondering if you guys had any tips for a TS wtw. I have only gotten it once and the boat was probably going 25mph and I just shot across the wake with little air but at around 22-23 mph when I try to get more vertical air its hard. Also any tips on my HS to get more air, sometimes I get pretty good air sometimes i just dont feel that pop. any help would be appreciated
http://www.youtube.com/watch?v=DBy80...ature=youtu.be
Old    Jay Simmo (JayManAR)      Join Date: Dec 2012       11-15-2013, 11:26 AM Reply
On TS, Make sure the boat initiates your cut for you instead of forcing the board to turn and cut in. Having the right amount of line tension all the way through the cut is key, and you will want to edge in more and more as you get closer to the wake. Start your cut in slow and let the boat send you across. Handle position is also a huge factor, keep it close to your hip/pocket and keep it in the same position so you don't give up any line tension. Also, stand tall at the top of the wake so your pop isn't absorbed. Once your focusing on all of that it's just a matter of being comfortable hitting the wake on your toes, practice it over and over again.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       11-15-2013, 12:05 PM Reply
I'm not very good, but....
The two keys on either toe or heel side are line tension (which you keep up by holding your edge) and not absorbing the wake with your knees.
On your vid, from both sides, you flatten out the board a bit as you go up the wake. This lets the line tension go and you get no pop. You have to hold the edge all the way through the top of the wake.
When I went to the boarding school they had me practice a script to make all my wake jumps the same. First cut out as far as possible. Then while the rope is a little slack, set up the handle and body position. As the boat starts to pull in to the wake, begin to edge. The closer you get, the more you edge. Don't let off till you are in the air.
Old    Nikolas Dramountanis (Greeko)      Join Date: May 2013       12-05-2013, 1:29 PM Reply
Which wake school did you go to SD?
