Old     (superair502)      Join Date: Mar 2010       11-05-2013, 11:50 AM Reply
Thinking about lifting my 2003 powerstroke 7.3 its a crew cab 4 wheel drive. plan on running 20 inch wheels and wanted some opinions on lift and tire size. I want a pretty substantial lift but it will be my first lifted vehicle, need input on suspension as Idk what I will need.
the truck will be used to tow an A22 or A24
some hiway miles daily about 20
mostly around ttown
some off roading.
mpg I somewhat care about but want off road capability and that lifted truck look
was thinking 35s on 20s with 6 inch lift? thoughts?
Old     (hunter660)      Join Date: Aug 2007       11-05-2013, 12:31 PM Reply
I would lift it the least I had to in order to clear 35s and call it a day. I would be looking at something in the 4" range if it were mine.
Old     (Griggs24)      Join Date: Oct 2013       11-05-2013, 12:47 PM Reply
Ford fender wells will allow larger tires with smaller lift.
Old     (superair502)      Join Date: Mar 2010       11-05-2013, 1:04 PM Reply
what size tires and lift is that? I have old style 7.3
Old     (Griggs24)      Join Date: Oct 2013       11-05-2013, 1:06 PM Reply
That's a 4.5 inch lift with 38 inch tires.
Old     (Supra24)      Join Date: Sep 2013       11-05-2013, 1:06 PM Reply
This. I think a Ford will fit 35's when leveled. At least I know the 6.0 did.
Old     (Griggs24)      Join Date: Oct 2013       11-05-2013, 1:11 PM Reply
I had 35 inch mudders on this ford with no lift. Truck actually road a lot better with that set up. I will say spend the extra money on a good lift. I went the cheap route and defiantly got what I paid for.
Old     (machloosy)      Join Date: Mar 2013       11-05-2013, 2:13 PM Reply
If you're going for 6" of lift, 37's are minimal. And while it'll fit bigger, your various components will start to wear aggressively. I'd stick to 4" and 35's or 37's. Mine was procomp 4" with dual front shocks, on 37's. It looked about right.
Old     (tyler97217)      Join Date: Aug 2004       11-05-2013, 2:14 PM Reply
That dog pissed on your tire.... Ha ha
Old     (phathom)      Join Date: Jun 2013       11-05-2013, 2:18 PM Reply
^ I just noticed that too lol.
Whatever lift you get, just make sure you get a decent enough drop on your hitch receiver so you can tow the boat level. Having a truck that sits too high and doesn't have a drop receiver to compensate is a real quick way to start gouging up your trailer on the driveway or worse.
Old     (bjames)      Join Date: May 2012       11-05-2013, 3:02 PM Reply
Your going to need a substantial drop hitch to tow your boat
Old     (Griggs24)      Join Date: Oct 2013       11-05-2013, 3:46 PM Reply
That's his normal spot. Guess he's trying to crack down on dry rot!
Old     (runin90lx)      Join Date: Sep 2009       11-05-2013, 4:54 PM Reply
my truck has a 6" BDS lift, dual fox shocks on front. fox shocks on back, and the fox stabilizing shocks up front. sitting on 38's on 24" wheels. it rides pretty good for being lifted. i will however probably go to 37" tires next set due to some rubbing on full turn when backing up a trailer, or if you hit a bump while hard turn parking etc.
also pulls the boat effortlessly and level with the correct drop hitch.
Old     (Gotmods)      Join Date: Nov 2012       11-05-2013, 7:17 PM Reply
4" 35's
6" 37's
8" 38's
I'm partial to 6" and 37's
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 8:56 AM Reply
I've got a 10 inch running 40x15.50 on 22s with 4.88 gears and lockers
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 8:59 AM Reply
Another
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 9:01 AM Reply
wheels are 22x14 fuel
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 9:12 AM Reply
not pulling anything i get about 20 to 21 mpg thats running 70. 75 is about 17 and 80 is about 15. pulling the x80 i get about 13 and thats running 75 to 80 down the road. to me fabtech is one of the better all around lifts out there
Old     (ddean)      Join Date: Dec 2006       11-06-2013, 9:13 AM Reply
4" RediLift with 35" Toyo AT's on 22" Fuels - 8k
Old     (Griggs24)      Join Date: Oct 2013       11-06-2013, 9:49 AM Reply
Originally Posted by Elliottsx80 View Post
Another
That thing is a beast. 6.4 I take it? How is the power with 40's?
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 10:30 AM Reply
With the 488 gears I put in it's great. Yea 6.4. I fully deleted it, no dpf or egr coolers with head studs and aftermarket turbos. spent many nights tuning it. Will waist my c6
Old     (Griggs24)      Join Date: Oct 2013       11-06-2013, 10:33 AM Reply
I was wondering how you were getting 20+ MPG out of the 6.4. Now I know! I have a full delete, intake, & plug in play tune and im pushing the 17-18 range with 38"s. Did you go twin turbo or just replace the sequential set up? Sorry for jacking the tread.
Mase: To answer your question on price. It can range depending on the lift and wheel/tire set up you go with. I went with the rough country lift & 18 inch KMC wheels on 38" toyo tires. Total investment with lift installed and front end aligned was a little over 5K. That is probably about the cheapest you will find. I don't really recommend the rough country lift but would take it over the ready lift any day. I know some of these guys have 10K-15K in there set ups. Really just depends on what kind of cheddar your willing to spend.
Old     (Elliottsx80)      Join Date: Feb 2012       11-06-2013, 11:22 AM Reply
went with a better seq. set up. and bigger up pipes.
MASE on your 03 is it leafs or coils up front. thats kinda a split year truck. if its leafs no matter what lift you do its going to ride like poo well unless you go to a coil over set up but thats going to cost you some $$$ been there done that. if its coils, they all ride pretty decent. the problem with later model fords with coils, the larger the lifts 8 + inches the more caster you loose and you cant hold them on the road unless you start fabing out some different rad. arm brackets and drops. or go all aftermarket. the ford in the pics drives like a cadi. only time i have to actually drive the truck is when our tax dollars missed a spot on the interstate where semis have caused ruts
Old     (jarrod)      Join Date: May 2003       11-06-2013, 11:52 AM Reply
Chase your truck is perfect. Gorgeous.
Old     (Griggs24)      Join Date: Oct 2013       11-06-2013, 12:00 PM Reply
Thanks bud. It has sure been a good truck for me.
Old     (superair502)      Join Date: Mar 2010       11-07-2013, 5:57 AM Reply
its springs all around, I am thinking 4 inch and 35s the more I look and read
Old     (board365)      Join Date: Mar 2011       11-07-2013, 2:44 PM Reply
Old     (board365)      Join Date: Mar 2011       11-07-2013, 2:47 PM Reply
I had this 08 F250sd had a 8in lift with 2in level sitting on 22's
Old     (superair502)      Join Date: Mar 2010       11-07-2013, 4:41 PM Reply
Meant to say leaf springs
Old     (markj)      Join Date: Apr 2005       11-08-2013, 5:28 PM Reply
Even though I'm a Ram fan, I like how the Fords can fit a big wheels without looking like a donk. I don't get why the rear ends are sagging so much in most of these pics though. Is that on purpose?
Old     (jonblarc7)      Join Date: Jul 2006       11-13-2013, 7:02 AM Reply
If anybody is looking for rims and tires I'm selling my 22" bmf Death Metal and 37" toyo open country off my truck. There in great shape and probably have 80% thread on the front and 90% on the back. I'm just wanting to run something smaller. 3000.00
Old     (jonblarc7)      Join Date: Jul 2006       11-13-2013, 7:03 AM Reply
pic
