Old    DocPhilMD            11-02-2013, 3:48 PM Reply
I am looking into this boat with the custom wake 9 sacs and pro ballast. I found a great deal including a trade in for my MXZ. Needless to say this is a lot of weight.
I am concerned that the 350 HP monsoon won't be able to handle this much weight.
Any thoughts/experiences out there?
Old    Dallas Cowboys #1 Fan Robert T (cwb4me)      Join Date: Apr 2010       11-02-2013, 4:35 PM Reply
What elevation are you going to be using your boat at?
Old    RB (boardman74)      Join Date: Jul 2012       11-02-2013, 5:29 PM Reply
I don't believe its the Monsoon motor. I'm pretty sure its the old indmar MCX. Anyhow it is rated at 350 hp.
Plenty of guys up here running Z3's with the 343 hp PCM(2013 motor) They are running plenty of weight and aren't having issues. Most have switched to the 1235 prop. Like Robert asked what elevation. If you are somewhere higher elevation it might not be enough. Lower areas I'm thinking you will be just fine. I know a guy who is a pro surfer running a Z3 with Pro ballast plus 1100 envo style sac in the surf side and have never heard him complain.
Old    TigeMike (chpthril)      Join Date: Oct 2007       11-02-2013, 6:18 PM Reply
A Monsoon is malibu engine and a Z3 is a Tige boat and the 2 will never meet. A Z3 with a 5.7L would be a PCM 343HP
Are you trading in the 22MXZ you just bought 2 days ago?
For surfing, the PCM 343 is prfect, but the factory prop is the weak spot when heavily loaded. No amount of HP or torque will fix a slipping prop.
Old    RB (boardman74)      Join Date: Jul 2012       11-02-2013, 6:25 PM Reply
I believe he is talking about the 2014 Z3 with the indmar 350 hp. But its not the same as the monsoon engine Malibu uses even though both are indmar. I was told its the Engine Mastercraft used to use as the "MCX". Tige calls it the M57.
Old    DocPhilMD            11-02-2013, 6:27 PM Reply
I live in Michigan so elevation not an issue
The boat has the 350 indmar. Tige changed to indmar for 2014. I am used to Malibu so I assumed it was a monsoon
I didn't buy my MXZ two days ago. I bought it this past spring
Old    RB (boardman74)      Join Date: Jul 2012       11-02-2013, 8:15 PM Reply
Its not the same engine as the monsoon. They are a malibu thing.
The 350 should be fine for you. I am in Minnesota and people are running them heavy just fine with the 343 PCM from 13. The new 350 Indmar in the 14's should do just fine.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       11-02-2013, 10:13 PM Reply
aside from the badging, how is an mcx or M57 or generic 5.7L that's in the MBs different from a monsoon?
Old    Art (rallyart)      Join Date: Nov 2006       11-02-2013, 10:29 PM Reply
You're fine with 350 hp. However, I have never heard anyone complain that they have too much power and I here many complain that they should have gone for more. The only time more HP cost money, aside from the day you buy it, is if you are running at WOT for top speed.
Old    Chris (cjh1669)      Join Date: Apr 2005       11-02-2013, 11:57 PM Reply
It's the M57. As in monsoon 5.7 lol. Same exact engine. 350 will do it for surfing heavy but that's about it. If I were you I'd go 450.
Old     (nitrousbird)      Join Date: Sep 2008       11-03-2013, 4:46 AM Reply
Monsoon is nothing more than a badging thing. It is the same motor.
Old    TigeMike (chpthril)      Join Date: Oct 2007       11-03-2013, 7:59 AM Reply
My bad, I had you mixed with another Bu owner that just picked up an MXZ a couple days ago.
Yeah, if you are looking at a brand new 2014, then it could have an Indmar, but could have a PCM if it was an early 2014 and Tige still have some PCMs left in the house.
Old    DocPhilMD            11-03-2013, 10:52 AM Reply
Any harm in getting the PCM? Any preference?
Old    Drew Richardson (surffresh)      Join Date: Jun 2010       11-03-2013, 11:45 AM Reply
You should wait and see what Indmar releases in two days…if it's a true game changer it could bring a lot back to the table or make your decision process even more difficult
Old    TigeMike (chpthril)      Join Date: Oct 2007       11-03-2013, 12:29 PM Reply
There all the same GM engine on the inside.
Old    Mason Obray (MCObray)      Join Date: Mar 2013       11-03-2013, 1:38 PM Reply
Ford 6.2L/Ford Eco Boost/ CVT.
Old    Ben Hovland (bhsupra22v)      Join Date: Jan 2013       11-03-2013, 8:40 PM Reply
Just got my 2014 Z3 with the LS3... I suggest that style...
Old    Timmy! (timmyb)      Join Date: Apr 2007       11-04-2013, 9:42 AM Reply
That engine will be fine for surfing but I think if you are loading it up and wakeboarding that you might want to pick a different engine. I drove a Z3 with the PCM 343 up here at 5200' loaded up for surfing and it was fine for that but no way would I want a wakeboarder hanging out on the rope for half the lake waiting to get to wakeboarding speed.
Old    Bruizza (bruizza)      Join Date: May 2009       11-04-2013, 11:42 AM Reply
If all you do is surf it will be fine. If you ever want to load up all the ballast and wakeboard there is a good chance it won't plane out if you have a good size crew.
Old    DocPhilMD            11-04-2013, 12:33 PM Reply
usually 5-6 adults max. surf 90% of the time. wakeboarders are beginner to intermediate
350 indmar ok?
Old    Timmy! (timmyb)      Join Date: Apr 2007       11-04-2013, 12:35 PM Reply
I think you should be fine with how you are using it. Have them throw in a prop upgrade just to make sure. Acme 1235 should be decent for that boat.
Old    Brendan (CarFanatic5)      Join Date: Apr 2010       11-04-2013, 3:15 PM Reply
I just ordered a 14 Z3 with the 350 motor. I ordered it with the acme 1235. I demoed a z1 with the 350 in it, and it had plenty of power for me. I also will be running wake 9 sacs. Thats why I got the 1235 prop.
