Old     (Fluffytoasters)      Join Date: Mar 2013       10-25-2013, 11:54 AM Reply
Hey everyone, I have just learned how to do a 360 but I am not consistent because the line has a lot of tension. I have tried a small progressive edge into the wake but then I don't have enough speed to clear the wake and end up casing it. if I go hard into the wake and then lay off my edge a lot before I hit the wake, will this create slack?
Old     (cwb4me)      Join Date: Apr 2010       10-25-2013, 2:33 PM Reply
You want to squat alot more and use your legs to create height. A wider cut will help build speed to the wake but the flat edge at the wake lessens the line tension.What line length are you riding at?
Old     (ferguson911)      Join Date: Sep 2013       10-29-2013, 8:07 AM Reply
As mentioned above a more squatted position will help. Also another thing to help you greatly! When you begin your pull on the handle it should be a 2 handed pull. If you begin your pull with 2 hands as long as possible it make a huge difference!
Old     (skiboarder)      Join Date: Oct 2006       10-29-2013, 8:18 AM Reply
You don't want slack. You want to never let the handle get away from you. Once it is gone…its gone.
One of the most common mistakes on a frontside 360 is people try to go from an edging handle position straight to their back hip. Try pulling the handle to your lead hip first (like a regular wake jump) and then across your body. It will make a big difference. It is easy to get away with the short cut on a 180, but it can be a huge problem for a 360.
Old     (Fluffytoasters)      Join Date: Mar 2013       10-30-2013, 10:15 AM Reply
Thanks guys
