Old    Daryn Dean (ddean)      Join Date: Dec 2006       10-23-2013, 7:07 AM Reply
Dinged the original and figured this was a perfect time to upgrade? Your guidance on how we get a bit more out of the hole when weighted?
Old    OldFatBald (EricU)      Join Date: May 2013       10-23-2013, 8:43 AM Reply
Just call Acme directly and they will help you pick the right prop, then ping Chpthril to order it
I am still amazed at the great personal service that Acme provides considering the volume of business they do
Old    Spencer (spencerwm)      Join Date: Feb 2009       10-23-2013, 8:45 AM Reply
Daryn,
What motor are you running and where are you located? What specific prop are you coming from?
Thanks,
Spence
Old    Kyle Closs (KyleCloss)      Join Date: Oct 2013       10-23-2013, 9:12 AM Reply
Daryn posted on my behalf while I was setting up my login. It is an '04 Xstar with the 350hp MCX motor. I am located in Dallas, TX and the boat has the factory prop today.
Old    Spencer (spencerwm)      Join Date: Feb 2009       10-23-2013, 9:54 AM Reply
Kyle,
I would check out the Acme 1285 or the OJ 470. You will get a lot better hole shot from either while loaded down. Your top end will decrease but the low end performance will be worth it.
Thanks,
Spence
Old    Kyle Closs (KyleCloss)      Join Date: Oct 2013       10-23-2013, 9:27 PM Reply
Thanks for the recommendations.
Kyle
Old    Curtis Hunter (PotatoShack)      Join Date: Aug 2013       10-24-2013, 3:41 AM Reply
I have a 5 blade prop ill let go for $300 I only used it two or three times.
Old    Curtis Hunter (PotatoShack)      Join Date: Aug 2013       10-24-2013, 5:56 AM Reply
Old    MCXSTAR (snork)      Join Date: Jun 2007       10-24-2013, 7:20 AM Reply
can't use that 5 blade on a Mastercraft XStar it needs to be splined 1 1/8
