Old     (MCObray)      Join Date: Mar 2013       10-18-2013, 9:46 AM Reply
Stats: 350 monsoon, 2315 prop, 750s in the locker, 400 in the bow, @ 11 MPH.
HB7T0Lg by Bucky Images, on Flickr
GOPR9235 by Bucky Images, on Flickr
GOPR9249 by Bucky Images, on Flickr
GOPR9260 by Bucky Images, on Flickr
GOPR9272 by Bucky Images, on Flickr
GOPR9273 by Bucky Images, on Flickr
GOPR9286 by Bucky Images, on Flickr
GOPR9304 by Bucky Images, on Flickr
GOPR9312 by Bucky Images, on Flickr
GOPR9333 by Bucky Images, on Flickr
GOPR9358 by Bucky Images, on Flickr
Old     (Greeko)      Join Date: May 2013       10-18-2013, 11:07 AM Reply
for a 23 footer...I was expecting a bit larger of a wave...
Maybe add more weight?...
Old     (MCObray)      Join Date: Mar 2013       10-18-2013, 11:13 AM Reply
It was rather large when riding... maybe the angle? Anywho, I was impressed with the wave. There was good length, ample push, maybe a bit steep, but you could get quite far out on the bottom turn's.
Old     (Greeko)      Join Date: May 2013       10-18-2013, 11:30 AM Reply
Yeah, probably the angle.. Mind you I just rode behind an 09 Centurion Enzo 244 and it was COLLOSAL!!! I guess I was expecting almost the same wave out of the Malibu..
Old     (Greeko)      Join Date: May 2013       10-18-2013, 11:32 AM Reply
is it closed loop cooling? Seems to have a bit of steam coming at you on the goofy side..
Old     (ragboy)      Join Date: Aug 2007       10-18-2013, 11:46 AM Reply
We just had a 2013 23 LSV at our polar bear event, although it was not the tallest wave, it was LONG, really long with good power. One of the things that was also very clear and seems to be shown in your pics, it makes a much better wake weighted, in other words, listed w/o SG.
IMG_7501 by wake9, on Flickr
DSC00202 by wake9, on Flickr
Old     (cjh1669)      Join Date: Apr 2005       10-18-2013, 1:52 PM Reply
Different boat, similar hull. From what I read about this on the malibucrew, they were running 750s in the rear and just 400 in the bow. Had a similar setup on a demo. Wake would be better with about 600 more lbs in the bow.
Old     (Alleykat)      Join Date: Jan 2013       10-18-2013, 2:06 PM Reply
You are correct on the wieghting of the 2014. I have been behind both versions, surfgate and listed 2013's. The 2014 performed much better with surfgate then the previous version. It's gonna have more potential due to more freeboard and deeper storage. Is it better than a fully listed version of the same boat? I dunno. But I know the answer to that on the previous hull and the listed wave is better.
1300lbs in the bow would be hairy, even with the higher freeboard. Excessive bow wieght kills push at times also, cant over do it.
Old     (Frankcondemslargesloths)      Join Date: Aug 2013       10-18-2013, 2:20 PM Reply
Are sg waves soft?
Old     (Alleykat)      Join Date: Jan 2013       10-18-2013, 2:23 PM Reply
Softer than a properly listed wave? They seem that way to me.
Old     (wakewoody)      Join Date: Sep 2010       10-18-2013, 4:05 PM Reply
I am in the market for a new Malibu. I have a great goofy wave on my listed 11 LSV. Tried a 13 LSV w/ surf gate. Wasn't completely sold. I don't know if you can even order the new boat without surf gate? Malibu's goofy wake is way better than its port wake when listed.if you could order it w/o surf gate, you would prolly have a hard time selling it down the road.
Old     (surfdoggy)      Join Date: Dec 2009       10-19-2013, 7:19 AM Reply
I have a 2009 Malibu 247. Slammed and leaned with 2600 lbs, the surf wake is great. Loaded flat with 2200 lbs, and a home made manual gate, the wake is better in every respect. Measurably taller by about 4", very slightly longer, better transition, more push, curls around behind the rider more, easier to catch - just more fun to ride. The only "advantage" of the leaned wake is if you If you like a much steeper face. I have the option of leaning it or using the gate - I always use the gate.
Old     (v10rider)      Join Date: Oct 2012       10-19-2013, 10:52 AM Reply
I think this has been discussed to death on malibu crew that listed wave is better than SG wave. SG wave is in no way bad but just not as good as a properly dialled listed wave.
For 95% of the buyers out there it is good enough and the ease of switching sides are a big plus. That being said I think the nautique with NSS seems to put out better wave.
Old     (scottb7)      Join Date: Oct 2012       10-19-2013, 11:31 AM Reply
That wave does look super long. Congrats.
Old     (pkh80)      Join Date: Oct 2012       10-20-2013, 9:42 AM Reply
Checkout what a 2013 LSV with Surf gate can do when properly weighted, I think the 2014 has even more potential. The only downside is that you are running a lot of ballast and I think LS3 will become the engine of choice for anyone serious about putting out a great wave.
Old     (ragboy)      Join Date: Aug 2007       10-20-2013, 7:11 PM Reply
The 23 LSV at the polar bear pictured only had the 350 in it, and it didnt' seem to have any issue with power, needed more freeboard, but power was fine.
Old     (MCObray)      Join Date: Mar 2013       10-21-2013, 12:00 AM Reply
The 350 in the '14 seemed to being maxing out. If I remember correctly, PKH80 who was driving some of the time, made a comment that it was struggling to go over 11 MPH. The LSV also got traditionally listed and the engine sound was noticeably smoother with some weight taken out of the goofy side... almost like there was less strain on the 350.
Old     (ragboy)      Join Date: Aug 2007       10-21-2013, 3:40 AM Reply
That is very interesting. I payed for all of the boats gas at the event they averaged from 4.5 to about 6.5 GPH, the bu and the MB at the higher end (the MB had 4500 lbs of ballast plus people) and all of the boats had ~350 HP motor options, except our Z3 with the 409. None of them had issues with power, but most were propped using something like the ACME 1235. I guess I just didnt' think about it til now, that listed vs non-listed would make that much of a difference in power needs, and I am guessing gas also.
Old     (Alleykat)      Join Date: Jan 2013       10-21-2013, 6:33 PM Reply
Makes sense. More surface drag when fully weighted. I was in that boat also, and the 350 is not enough for the new LSV. I don't think they should even build that boat with the 350.
Old     (ragboy)      Join Date: Aug 2007       10-21-2013, 11:21 PM Reply
So how much weight are you running to get that wake with SG?
