Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       10-14-2013, 5:01 PM Reply
Yesterday, it wouldn’t start. Checked dist cap, and it had moisture in it. Dryed it out and starts fine now, but now I’m heairng a loud air sucking sound coming from the throttle body. Does any one know why? shouldn’t that sound go away once you put the air filter on? its not as loud with the air filter on, but it never used to be this loud??? Is it bad to run this way?Did I lose a gasket or something?
Old    Tom (boardjnky4)      Join Date: Dec 2011       10-14-2013, 6:44 PM Reply
IAC valve muffler is probably missing. Not a problem just annoying.
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       10-14-2013, 6:46 PM Reply
is that in the throttle body? and leads to the IAC?
Old    Tom (boardjnky4)      Join Date: Dec 2011       10-14-2013, 7:22 PM Reply
Yep, it's just a small little piece of fabric-like material that jams into the opening of the IAC (from the throttle body) that muffles the sound.
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       10-14-2013, 7:31 PM Reply
Thanks! I’m picking one up tomorrow!
Old    Sue (malibu)      Join Date: Sep 2004       10-14-2013, 7:35 PM Reply
Tony Joe and I had an IAC muffler problem with our previous boat, an 05 Sanger - same engine as yours. The IAC muffler is a little foam square shaped device located in the throttle body. Ours was clogged up with black paint from the factory when the boat was new. Our Sanger wouldn't idle and the engine would die at important times like when you were coming into the trailer or a dock. It was a pain! We took it to several mechanics and no one could figure it out.When one finally did and he put a new IAC muffler on and it idled perfect.
Old    Tom (boardjnky4)      Join Date: Dec 2011       10-15-2013, 5:44 AM Reply
Had the same problem with mine. It took a lot of googling to figure that one out.
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       10-15-2013, 9:17 AM Reply
I'm gonna be sooo happy if this fixes my idling prob! ( I had that too!) Where do you think the darn thing went? ( foam square) I had the spark arrester off, when I was tryin to start it Sun, and it kinda back fired thru the throttle body. Do you think it could have blown it out then? or sucked it in?
Old    Tom (boardjnky4)      Join Date: Dec 2011       10-15-2013, 3:25 PM Reply
It shouldn't idle badly if it's simply missing. If one exists and is clogged, that will cause rough idle.
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       10-16-2013, 10:09 AM Reply
Back up and running! Seems to idle a lot better. Going out tomorrow for a test! Still sunny up here in the PNW this week, and the temp is perfect at 65 degrees!
