Old     (bburns4667)      Join Date: Sep 2013       09-09-2013, 12:23 AM Reply
just started trying it.. this is the best one we got on camera... i got real close to landing one but caught ts edge..
Also What can i do to clean my wake up.. its a 1998 regal 2100lsr with that damn fasttrac hull design.. only had 3 people in the boat and no fatsacks high five prop
http://www.youtube.com/watch?v=YmihW...IB7KXPZdQt1cWA
Old     (DenverRider)      Join Date: Feb 2013       09-09-2013, 8:03 AM Reply
Your front leg is poked out too much causing you to rotate. You're probably a little scared which causes you to get on your back leg as you shy away from the wake. That's what causes you to stargaze and land on your back. If you balance your weight from leg to leg equally and get the rotation under control then your board should naturally drop back underneath you so you can land it.
also ... turn the camera width wise and zoom in.
Old     (bburns4667)      Join Date: Sep 2013       09-09-2013, 8:42 AM Reply
its only like that cause i ripped it off facebook it only rips video in the damn vertical format.. i have a gopro on the back of the boat but it was dusk and didnt show up goood. couldnt see me through the tree line.
Old     (AustinMHayward)      Join Date: Jun 2013       09-09-2013, 4:33 PM Reply
Try adjusting the trim up a couple of notches up to clean the wake up.
Old     (Jmaxymek)      Join Date: Feb 2012       09-10-2013, 10:26 PM Reply
Look at your line through the trick. Keep your head up and stare straight up your mainline/at the boat, it will help keep you from rolling like that.
Old     (mwsriders)      Join Date: Dec 2007       11-01-2013, 7:15 AM Reply
Eric is right, if you are stargazing, you have too much weight on your back foot. Square up through the wake so you have even pressure on both feet and get that board inbetween you and the boat right before takeoff.
