Old    Mike (mfenton)      Join Date: May 2009       09-01-2013, 11:37 AM Reply
2007 super air 220.
Was surfing and perfect pass beeped a couple times. Now it is stuck on 6 mph and when I adjust speed it goes right back to 6. I tried to reset it but when it tells me to hit the up arrow for reset it won't do anything.
Any ideas?
Thanks
Old    Surf Addict (Desi) (phathom)      Join Date: Jun 2013       09-01-2013, 5:05 PM Reply
What's the voltage reading? Perfect pass does some funny stuff with low voltage.
Old    Tim (dezul)      Join Date: Jul 2012       09-02-2013, 4:54 AM Reply
Sounds a little like my problem this weekend. Mine just started losing and regaining readings from the gps. System reset worked for a minute but problem conitued. Does your up arrow normally work?
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       09-02-2013, 8:33 AM Reply
I would say low voltage too!!! I had the same problem this year with the display not working right. I put the batteries on a charger and the next day it work like normal. Perfect pass is very sensitive to voltage.
Old    Tim (dezul)      Join Date: Jul 2012       09-03-2013, 6:38 AM Reply
It definitely is not low voltage for me. I charged both of my batteries overnight. When I put them on the charger, the voltage was reading 12.8v. The problem existed before and after charging.
Old    Tim (dezul)      Join Date: Jul 2012       09-03-2013, 6:52 AM Reply
Judging by what PP says on their website, it may be a wiring issue. I will investigate and see.
Old    Frank Berg (Iceberg)      Join Date: Dec 2011       09-03-2013, 7:43 AM Reply
As you are becoming aware, wiring issues will act like low voltage or power. PP doesn't need much power, but a bad connection will behave the same way. It is possible your head is faulty.
