Old    James Woolsey (Jamesy94)      Join Date: Aug 2013       08-29-2013, 3:43 PM Reply
I can't clear the wake but I am not sure what I am doing wrong. Here is a video http://www.youtube.com/watch?v=lX2eHnBaaIw
Any help would be greatly appreciated
Old    Dallas Cowboys #1 Fan Robert T (cwb4me)      Join Date: Apr 2010       08-29-2013, 3:50 PM Reply
First off you need to take a progressive approach to the wake. Build you edge till you get to your most aggressive edge at the wake.Also you need to stand tall like on a trampoline or a diving board.Then you will get pop off the wake and easily clear the wake. Good Luck!
Old    Eric (DenverRider)      Join Date: Feb 2013       08-29-2013, 5:32 PM Reply
What length is your rope? It's looks a bit long for the wake of that boat. The wake looks like it has a bit more of a peak several feet in front of you and then flattens out where you hit it. It's more narrow when you're closer as well and therefore easier to clear.
Old    MCXSTAR (snork)      Join Date: Jun 2007       08-30-2013, 5:24 AM Reply
What wake?
perhaps slow the boat down, trim the motor out some causing the bow to rise
I'd start from there
Old    James Woolsey (Jamesy94)      Join Date: Aug 2013       08-30-2013, 5:43 AM Reply
My rope length is 55' . I will try it a bit shorter and try pop a bit more
Thanks for your advice
I'll let yous know how I get on
Old    Orion (chillinoj)      Join Date: May 2009       08-30-2013, 6:04 AM Reply
Charge Harder! haha that always helps...
Old    Hot Tub Tony (HotTubTony)      Join Date: Jun 2013       08-30-2013, 7:08 AM Reply
First, you should not use a baseball grip on the handle; hold it with palms down to help keep tension on the line. What helped me is to not try to turn and edge towards the wake at all. Edge out, then wait for the boat to start pulling you back towards the wake (be patient). As that happens, look up the line, get on your heels, and try to get more & more tension on the line as you get closer to the wake. When you get to the bottom of the wake, start to stand up by pushing off the heels; don't absorb the pop with your knees. The goal is to have the most spray coming off your board at the wake and tension on the line. Once you get it, you will be surprised how easy it is to get across. Good luck!
Old    Frank Berg (Iceberg)      Join Date: Dec 2011       09-01-2013, 6:45 AM Reply
From your video there are some issues, the first being your pop. If you notice, your legs are still collapsed as you leave the wake - your timing off. The second is the wake shape. You have very little ramp, so it makes it difficult to get height. The biggest problems I see when teaching people to jump is lack of timing and the sense that the jumper is way off the surface when they are only slightly above it. Since your wake is small, you will have to ensure you are at full extension before/at the lip. If you can, try slowing the boat down to get a better wake, or adding some ballast. Have fun work on the lip timing and when you start getting some pop, increase your cut and speed to go W-W.
Old    James Woolsey (Jamesy94)      Join Date: Aug 2013       09-03-2013, 8:21 AM Reply
I still haven't got it yet but hopefully I will before the season ends. I just need need a bit more practice getting it all right but thanks for your replies
