Old    Pierre-Hugues Lepine (phl)      Join Date: Aug 2013       08-28-2013, 12:16 PM Reply
Hi, i just bought my first surf boat and i was wondering if some one can help me with the fat sac setup. For the moment i do full rear left ballast + a 400lbs in the rear left compartment + a 400lbs fat sac on the left side bench + center ballast full. is there any better set-up then that ?
Thanks
Old    Harold Hemming (h20king)      Join Date: Dec 2009       08-28-2013, 12:41 PM Reply
Stock ballast full an 1100 in the rear and a 600 under the port side seat
Old    Drew Richardson (surffresh)      Join Date: Jun 2010       08-28-2013, 1:25 PM Reply
are they still selling them as "Surf Boats" with 750 total ballast ?
Old    Pierre-Hugues Lepine (phl)      Join Date: Aug 2013       08-28-2013, 3:24 PM Reply
T Hey have around 2000lbs of stock ballast! Thanks Harold I ll te this!
Old    Drew Richardson (surffresh)      Join Date: Jun 2010       08-28-2013, 3:28 PM Reply
that's cool and a ton better than the 750 my 2011 had in it
Old    Pierre-Hugues Lepine (phl)      Join Date: Aug 2013       08-28-2013, 4:24 PM Reply
You should buy à 2013 or à 2014 in that case
Old    Drew Richardson (surffresh)      Join Date: Jun 2010       08-28-2013, 5:42 PM Reply
LOL, old timers on here know why
Old    Jason Callen (westsidarider)      Join Date: Feb 2003       08-28-2013, 6:50 PM Reply
Add a sac in the bow as well. It will make the wave longer and push more
Old    Travis Q (motogod77)      Join Date: Aug 2008       08-29-2013, 9:38 AM Reply
Every Supreme v226 built from day one through 2013 has 1200 lbs of factory hard tanks, 350 in each rear corner and a 500 lb center tank. Like H said, 1100's in the rear compartments and a 400-600 under the port bench and bam!
Old    Stephane Leblanc (Stefl73)      Join Date: Apr 2013       12-14-2013, 11:49 AM Reply
Wrong Travis! I have a 2009 V226 and i don't have front 500lb in the front. The switch is on the dashboard but there is no center tank. Pierre-Hugues, Bon achat! j'adore mon 2009 donc ton 2013 doit être l'enfer... Enjoy
Old    D (Cabledog)      Join Date: Dec 2013       12-14-2013, 12:27 PM Reply
I Don't speak French but I just sold a 2003 Supreme V220 SP with the Sky package. It had the rear hard tanks and a switch for the center too but no tank. Made sure the new V226 had one before I bought this time. I use the factory center with custom Enzo style rear sacs that fill the lockers and under the side benches. 1100lb + per side. I will dial it in this spring.
